Old 03-12-2017, 10:50 AM   #1
gandolf
ECU: standard ECU
Default rechipping
can the 1600 be rechipped and what benifit would this bring or the down side if any.
Old 03-12-2017, 01:44 PM   #2
I don't remember seeing which ECU you are using but provided it's the MEMS 3 (Motorola) type then this can be remapped.
Kmaps is the most commonly used company for these engines. Loads of people used and recommended them.
Visit www.kmaps.co.uk for more information.
Old 04-12-2017, 08:22 AM   #3
Nice sales pitch! how much commission did you get for that ?
Old 04-12-2017, 10:08 AM   #4
Ha ha. I am planning to use them myself.
I have also contacted at least 3 other companies who do this kind of work who say it's probably best going direct to Kmaps. When you are in direct competition with someone and end up recommending the original company, I think that says something for them.
Just for the record, also try these.
https://www.sawstuning.co.uk/
http://www.jctuning.co.uk/
Sorry cannot remember the others.
The thing is mine is a turbo engine. They don't have a base map for this so Kmaps have a tried and tested setup used by quite a few people on here.
You may be able to get a local remapping company to do this provided they have the correct leads and software. If your engine is close to standard, (but reading the part of your "about you" says you are running carbs) not sure what you are wanting to gain. Surely the ECU is only controlling the spark if that's the case.
