Old 15-10-2017, 01:59 AM   #1
Default Oil filter take off Adaptor
Found this while searching the tinternet,
http://www.mattlewisracing.co.uk/pro...t_lewis_racing
Old 15-10-2017, 06:40 AM   #2
Got a spare one in the garage, I was going to look at getting some made up as the Mocal ones are scandalous
Old 15-10-2017, 06:17 PM   #3
Just a bit
Old 15-10-2017, 07:32 PM   #4
twincamtone
twincamtone's Avatar
ECU: Standard MEMS3
I was looking at those too, but decided I would make my own so bought a billet of alloy big enough to make two and 1/2"bsp tap and drill to suitable to drill the hole to be threaded, and a couple of 1/2"bsp fittings all for about 55.
Still a waste of money though as everything clears the oil filter housing anyway
Old 18-10-2017, 11:30 AM   #5
ZA-J
I was tempted to buy one when I first saw it, then saw the price!
Now looks like I’m going to make one!
Is a pressure switch needed for the each or can I happily swop over to capillary gauge and not bother with the switch?
Old 18-10-2017, 11:43 AM   #6
Phaeton
Phaeton's Avatar
Depends if you think you think a little itsy bitsy needle in your peripheral vision is going to be as effective as a big RED light in plain sight to get you to switch your engine off before it gets destroyed as you've lost oil pressure.
Old 18-10-2017, 01:07 PM   #7
The problem is by the time the light comes on the chances are there will be damage already done. Personally I prefer a gauge AND a light using a t-piece as you have the potential of spotting dropping oil pressure and the light then acts as a failsafe if you miss it.
Old 18-10-2017, 05:22 PM   #8
ZA-J
Bloody predictive text.....that meant to say is it needed for the ecu. I plan on using capillary line anyway, just not sure if the ecu has some sort of tie up with oil pressure?
