Old 11-10-2017, 01:39 PM   #1
gandolf
ECU: standard ECU
Default three new alternators
First new alternator in dec. 16,2nd in April 17 and now third.They just stopped charging it has to be a problem caused by the car anybody have an idea what may be causing this.I don't think supplier will give me a fourth in feb 18.
Old 11-10-2017, 01:49 PM   #2
Could be getting cooked or getting too much weather, I’d use a heat shield to protect it from both the heat and weather.
I can’t think of anything else obvious.
Old 11-10-2017, 02:27 PM   #3
will16
will16's Avatar
ECU: K Maps 170
Does your ignition light work?
Old 11-10-2017, 02:32 PM   #4
gandolf
ECU: standard ECU
Yes ignition light works voltage meter shows no charge, battery shows no charge when revved.
Old 11-10-2017, 03:07 PM   #5
richie08
richie08's Avatar
CC: 1396
ECU: Rover mems
Bad engine earth?
Old 11-10-2017, 03:13 PM   #6
Ken555
Ken555's Avatar
CC: 1590
ECU: PW0 with custom map
Overspeed ?
Are you using the same crank pulley ?
Ken555 is offline   Reply With Quote
Old 11-10-2017, 06:11 PM   #7
gandolf
ECU: standard ECU
Originally Posted by Ken555 View Post
Overspeed ?
The engine is a standard 1600.
Old 11-10-2017, 09:41 PM   #8
Shit alternator brand? What's the rest of your car like electrically still on mems or something else?
I used to go through alternators when I daily drove my mini but usually they would start screaming first as the bearings got chewed up from water and grime flung up from the tyre.
Old 12-10-2017, 07:27 AM   #9
Are you using it in the correct direction of rotation? Some can be used either direction with their cooling fan others can't or may need cooling fan of different direction. Just guessing.
Old 12-10-2017, 07:41 AM   #10
gandolf
ECU: standard ECU
Evolution the car is still on mems 3. Birdman the alternator is in the standard position. The original one with the engine was the Bosch and must have lasted 16 yrs,these are from Europarts and according to the box are made for europarts.Evolution may be right ,but lasting just the same amount of time.I think I need to carry a spare.
Old 12-10-2017, 10:09 AM   #11
As its on mems just double check the high current wiring carefully for chaffage and when the cars running lights on etc measure the voltage between the alternator + bolt and the + on the battery there should be less than 0.2v drop with lights/wipers/rear screen on . if the drop is greater then use the meter to narrow down on what wire run or joint is failing.
I would also go on ebay and get a clean looking used alternator and try that too...
Have had a lot of bad luck with reman alternators lately.
Old 12-10-2017, 11:39 AM   #12
gandolf
ECU: standard ECU
Thanks for the help Dennis
Old 13-10-2017, 04:52 PM   #13
gandolf
ECU: standard ECU
Well after receiving my third alternator (the wrong one) I now have the correct one and is charging at 15 volts with revs above 3500 as was my other two.Is this right or too high?
Old 13-10-2017, 05:06 PM   #14
Too high. I have a digital reading on my dash. Highest it gets is 14.2v. It only reads that for a couple of minutes then drops under 14v for rest of the day.
Old 13-10-2017, 05:25 PM   #15
gandolf
ECU: standard ECU
thanks Andy ,what do you think can cause this?
