Old 20-12-2016, 10:22 AM   #1
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
Default 4.1 or 3.5 diff dilemma
As title says, ready to put my gripper in and toying with the idea to change the final, but unsure if i destroy the trackabaility of the car then?
It feels like it when looking at the graphs below, 4.1 vs 3.5
3.5 on 10"s gives the exact same gear ratio as 4.1 with stock swift wheels and tires
Anyone now a supplier of Mk1 gearbox rebuild kits?
Skärmavbild 2016-12-20 kl. 11.15.44 by G13B, on Flickr
Skärmavbild 2016-12-20 kl. 11.15.21 by G13B, on Flickr
Old 20-12-2016, 11:32 AM   #2
DVO
DVO's Avatar
ECU: Chipped
I drove both and the 3.5 really takes the bite, and for that, the fun out of it. Only consider it when you do a lot of highway or regular normal use.
I am using my car just for fun and trackdays and for that 4.1 is perfect.
Dennis
Old 20-12-2016, 01:34 PM   #3
Marcus Nordblom
ECU: 40mm mikuni rs
Dennis
Cheers for that Dennis,
Nice to hear from someone that have tried both setups!
Motor is pretty tuned now and I guess loosing low down grunt doesn't help either - i stick with 4.1
Just stay clear of the highways and go fast on the B roads
Old 20-12-2016, 10:06 PM   #4
You can go for 3.78:1 which will be good for both.
I have been in 4.1:1 in the mini, also I have been in mk1 Gti I used own.
I think bulk ring and all that is same for mk1 and mk2.
Atchi
Old 21-12-2016, 10:46 AM   #5
Marcus Nordblom
ECU: 40mm mikuni rs
Done a couple of track days with 4.1, about perfect when you actually use 5th gear on the straight
From which model do you extract the 3.78 diff Atchi? As you say maybe it´s the golden middle way, i will do more miles on the street than on the track
Old 21-12-2016, 10:48 AM   #6
Domcr250
I've run 4.1 and 3.5.
Mine is used on the road, so I find the 3.5 easier to live with. On a road car with 10's I found the 4.1 made 1st gear almost redundant.
This debate has been run before and the consensus seems to be if you are going to use it on trackdays then the 4.1 works very well.
Old 22-12-2016, 11:59 AM   #7
I will check which model it is from for you.
I have a feeling it is from 5 door G13A model but I will check for sure.
Atchi
Old 22-12-2016, 10:23 PM   #8
Hi,
I have checked it now and it is from AA53A so it is for G13A 5Dr mk1 Swift has them in.
If you can find them, you can fit these in and will work better for your car.
I myself has this ratio for my Mini with 13".
Atchi
Old 22-12-2016, 10:56 PM   #9
Marcus Nordblom
ECU: 40mm mikuni rs
Originally Posted by miniswift View Post
Hi,
Atchi
Thanks Atchi, i will try finding oneold Suzuki parts is cheap as chips have found a couple of boxes £40 a piece
Old 23-12-2016, 10:35 AM   #10
not many in UK, so I might ask you the get me a set!
Old 23-12-2016, 10:48 AM   #11
Marcus Nordblom
ECU: 40mm mikuni rs
I keep my eyes open
