Old 27-11-2016, 11:32 AM   #16
sebastiaan.keijzer
ECU: KMS
Originally Posted by iSonic View Post
Hi Sebastiaan,
Does the braking differs much from a 8.4 inch 4 pot brake setup? Do you use the original mini pedalbox or something else?
Looks interesting! I have been thinkink about the superfastmini kit but its quite expensive seeing the exchange rates...
Yes! It brakes better but how mutch better.... Im happy with the setup. Make it yourself. Ask the guy thats provide the axle sleeve service for the spacers. If he can make them for a good price than your better off making the kit yourself.
Im using a yellow tag master cilinder.
Regards,
Sebastiaan
sebastiaan.keijzer is offline   Reply With Quote
Old 27-11-2016, 11:44 AM   #17
iSonic
ECU: -
Thanks. Did you have to make drawings for the spacer?
I am considering the obp pedal box (http://www.obpltd.com/Pedal-Boxes/Classic-Mini) but read some bad stories about them... The topics about them are all old however and they claim to have improved them by using folded pedals...
And with buying the kit I ment buying their big brake kit.....
iSonic is offline   Reply With Quote
Old 12-03-2017, 07:40 AM   #18
iSonic
ECU: -
Ordered the calipers and discs! Looking for somebody who can make the spacers!
Old 12-03-2017, 10:35 AM   #19
sebastiaan.keijzer
ECU: KMS
Ask Abrand. Hé van help you. He did my driveshafts and some other things. Really good price and service!
Old 16-03-2017, 11:07 AM   #20
mininut
ECU: Trionic 5.5
The "spacer" you added to the bottom knuckle, how much of a difference in camber under compression have you noticed? has it affected your rollcentre in a positive way using it on a car that isn't 1" off the floor like the ones its designed for?
Old 16-03-2017, 08:54 PM   #21
sebastiaan.keijzer
ECU: KMS
Sorry, cant say anything about the setup. I sold the Estate. I now have a other project and the brake ar going on that mini. Will take a lot off time befor i can drive the mini....
Old 17-03-2017, 05:07 PM   #22
DVO
DVO's Avatar
ECU: Chipped
Hurry up then
Dennis
Old 22-03-2017, 07:49 AM   #23
iSonic
ECU: -
Hmm somehow the force seems to be against me! First received the wrong discs. And now track and trace show the calipers were in Amsterdam, Schiphol but are now on their way back to Miami.....
Old 22-03-2017, 08:34 AM   #24
sebastiaan.keijzer
ECU: KMS
Thats stange!
Old 23-03-2017, 10:12 AM   #25
iSonic
ECU: -
Oke the correct discs are in and apparently the calipers have cleared customs and on the way to my home....
