Old 11-09-2016, 06:30 PM   #1
KMG
CC: 1293
Default First startup
I will hopefully be getting my short block back soon with new pistons,big end bearings and I was wondering is there any way to prime the oil pump before starting and anything else I should do before I turn the key for the first time.
Old 11-09-2016, 08:31 PM   #2
mikko
mikko's Avatar
ECU: obd0
you could crank it over without the plugs in for 30 seconds or so but its unnecessary, thats what assembly lube is for.
Old 11-09-2016, 11:27 PM   #3
as mikko! don't forget to put oil in it lol, wang it over and your away, we hope,
Old 12-09-2016, 04:14 AM   #4
I unplugged the injectors on my K series and cranked it until the oil pressure light went out, I also pre-filled the oil pump as well as using Torco assembly lube when I built the engine.
