Old 26-04-2016, 02:48 PM   #1
Alex1380
ECU: Megasquirts
Default phantom grip and LSD type talk
Hey,
So one of the big problems i have is getting traction off the line and though some corners. I've added a rear anti roll bar and coilovers to try and help the cornering traction issue however i do keep thinking about an LSD.
I keep seeing a Phantom gripper thing coming up which looks like it fits inside the standard diff and i assume puts pressure on the planet gears to lock them together to a point before it starts to slip. I get the concept however i'm not convinced.
The other option seems to be a real LSD however i'm expecting this to be expensive.
What are peoples thoughts and experiences?
Old 26-04-2016, 08:36 PM   #2
I know a person with LSD for sale.
If you would like I can ask hoe much he wants to sell it?
I think it was Suzuki Sports LSD which I imported....
If you are to go for Phantom Grip, I will suggest bike wet clutch plate to be glued on to planet gear so that grip surface is not metal to metal. I had CAD data when I made one for myself over 10 years ago. It is just 13mm plate with 4 small coil springs with heat treatments. Yopu can make them for about 40 but you will need to have access to machine shop.
I think Jerry's son Jimbo got my PG LSD.
So you have 2 choices.. actual LSD or PG LSD I made.
Oh, Allan used my PG LSD in his Wolf and he said it works OK!
Atchi
Old 27-04-2016, 12:30 PM   #3
Alex1380
ECU: Megasquirts
How do you work out the spring pressures for a PG type LSD?
Personally i think i'd rather go for an actual LSD. If you could get me a price i'd be interested. I'm currently running a 1.3GLX gearbox so i should probably rebuild the gear set in to a GTI gearbox case as i believe they are diffrent
Old 30-04-2016, 08:20 PM   #4
sent you pm!
Old 03-05-2016, 09:19 AM   #5
Alex1380
ECU: Megasquirts
cheers. Whats your advice regarding gearbox cases?
Old 03-05-2016, 01:26 PM   #6
G13 gearboxes are all same externally.
Only difference is that ratios of 3rd-5th been closer in Gti.
You could change pinion and crown wheel from your GLX to Gti so you have 3.78:1 ratio to go with Gti gears.
Atchi
Old 15-05-2016, 08:23 AM   #7
substitute
substitute's Avatar
ECU: Stock Suzuki
Hi I have a GTI box and am looking for a 3.52 FD to run 10" wheels. Happy to swap whole GTI box for GLX box or just FD if you're interested?
PM me?
Quietly getting on with it...
Old 17-05-2016, 09:51 AM   #8
Alex1380
ECU: Megasquirts
sorry i've already got a a GTI box and the GLX box.
Old 17-05-2016, 12:57 PM   #9
DVO
DVO's Avatar
ECU: Chipped
Got a box like that available, but I am in The Netherlands.
Dennis
Old 17-05-2016, 04:42 PM   #10
bobjonah
bobjonah's Avatar
Me too, but I am in Canada. If you cannot find one locally, I suppose that I could strip off the output shaft and just send you that with the ring gear. Let me know if you need it, and I will get a cost for shipping.
Bob
Old 18-05-2016, 06:19 AM   #11
substitute
substitute's Avatar
ECU: Stock Suzuki
Dennis
Hi Dennis,
Seems you have 2 of the things I'm after; Conversion Plate and GLX 'box
Can we do a deal for both?
Keith
Old 18-05-2016, 06:42 AM   #12
DVO
DVO's Avatar
ECU: Chipped
Ofcourse, but a Suzuki box and a conversionplate for a Vauxhall box
Dennis
BTW Some people are talking about a GLX box, but here in The Netherlands you also had a 1.0 GLX, what you are after is a non Gti 1.3 box !!
Old 18-05-2016, 04:10 PM   #13
substitute
substitute's Avatar
ECU: Stock Suzuki
Paul's Green One needs the 3.52 FD to run 10" wheels.
I am after a conversion plate to continue playing with and improving the Blue One
Plus... I have projects/experiments planned for the 2 shells I still have... one at a time
Yes, I am aware of the 1.0GLX but had assumed from the thread that yours is the 1.3GLX 'box
Old 18-05-2016, 04:14 PM   #14
I know a mk1 Gti gearbox with 3.528:1 ratio.
It used to be mine and I sold it to my mate but I'm not sure he will everr use it to be honest!
He is more into Micra conversion now.
Let me know, if you are interested.
Atchi
Old 18-05-2016, 04:40 PM   #15
substitute
substitute's Avatar
ECU: Stock Suzuki
Atchi
Will do. Thanks Atchi
