Old 14-06-2016, 10:56 PM   #31
adriantillin
Originally Posted by substitute View Post
I believe you can fit the suzuki speedo into the mini binacle. That's our plan for The Green One
Thanks for the tip - I'll look into it
Cheers Adrian
adriantillin is offline   Reply With Quote
Old 23-06-2016, 05:47 AM   #32
adriantillin
My engineer popped round this morning and confirmed everything is now compliant with VSB14 Code LA2. He issued me with a Certificate of Modification and attached the blue modplate (see photo).
This afternoon, I've registered the changes with DTMR (which cost nothing ) and let my insurance company (Shannons) know. They've charged me an extra $34 annual premium for the twin cam engine swap (which includes upping the agree value from $16k to $20k). Very pleased with that outcome.
So the bottom line is MOK111 is 100% legal and ready for the road.
Cheers Adrian
Old 25-06-2016, 04:24 PM   #33
substitute
substitute's Avatar
ECU: Stock Suzuki
Excellent News �� Well done and well deserved ����
Quietly getting on with it...
Old 25-06-2016, 09:58 PM   #34
adriantillin
Thanks mate - bigger throttle body, bored out AFM and ECU chip next
Cheers Adrian
Old 26-06-2016, 09:08 PM   #35
KMG
CC: 1293
Congrats on getting it road legal,bet it really flies along.
Old 26-06-2016, 10:14 PM   #36
adriantillin
Thanks - it does nip along Quickest Mini/Moke I've ever owned over 35 years.
Cheers Adrian
Old 23-07-2016, 09:17 PM   #37
adriantillin
Finally got round to rigging up a video camera in the Moke to record a longer clip with the 16v twin cam motor installed. Car is running really well with approx. 500kms under the belt. I also found some video compression and editing software (but its mucked about with the synchronisation of the audio). Sound quality not the best either as the camera is up on the roll bar in the wind - but you'll get the idea. Guess I wont be taking up film production any time soon (I'll stick to Moke renos).
https://1drv.ms/v/s!AhDswuqVPDDRrh6To8st80i4ZmAV
Cheers Adrian
Old 24-07-2016, 07:20 AM   #38
Mini Vlatko
Mini Vlatko's Avatar
Love this build but still not sure why is not in build section? :O
Old 25-07-2016, 09:06 AM   #39
adriantillin
If one of the mods wants to move it, that's fine with me
Cheers Adrian
Old 26-07-2016, 10:49 AM   #40
thanks for the vid, your loving it,
yes the softwere has messed it up, try without, think youtube dose it for you,
Old 27-07-2016, 11:46 AM   #41
adriantillin
Thanks mate - I'll give it a go
Old 09-02-2017, 08:12 AM   #42
adriantillin
Been a while since I had anything to report on the 16v Moke front (although the kms have been ticking up). That said, over the past couple of weeks I've been chipping away in the background with upgrades and things are just about ready for the rolling road.
I've fitted a bigger throttle body (60mm up from 45mm), bored out the inlet manifold plenum to 60mm, bored out the Air Flow Meter housing from 45mm to 49mm and relocated it at the air filter, fitted a polished aluminium hi-flow fuel rail, had the injectors, cleaned, tested and serviced, fitted an adjustable fuel pressure regulator (to allow for the necessary up in fuel pressure), fitted a Grp A chipped ECU and re-routed a bunch of fuel lines and electrical cables. Rather than read all the words, look at the pictures below (the 1st three are with the induction pipework removed, the 2nd three are with everything back in place).
Fingers crossed for a reasonable power boost - a similar set up in a modded Suzuki Swift made 100bhp at the wheels.
Cheers Adrian
Old 09-02-2017, 08:14 AM   #43
adriantillin
MOKIII went in for the rolling road set-up this morning. After 90 mins of playing with fuel pressure and timing, the results are good. 101 Motorsport at Springwood did a great job. We ended up raising the fuel pressure by a massive 28psi to 68psi at warm idle but that gave the necessary A/F ratio to avoid leaning out across the rev range. As you can see from the print out below, the G13B motor now makes 90bhp at the wheels (approx. 115bhp at the flywheel) and at a calculated 185kph .
The torque curve is also really good. Verun (owner) thought we might get a bit more but as the final run was at 8000rpm, we didn't want to push our luck at this point in time. I was secretly hoping for nearer 100bhp atw but really happy with the driveability and improvement over the standard ECU and throttle body. After all, it is up 20bhp from standard G13B spec ;D
Big smiles on the drive back.
Cheers Adrian
Old 15-02-2017, 02:11 PM   #44
DVO
DVO's Avatar
ECU: Chipped
Nice result, but is a G13B only 70HP on the wheels in standard trim?
Dennis
Old 16-02-2017, 08:42 AM   #45
adriantillin
Dennis
Mk1 is 95 at the flywheel (with approx. 25 losses)
Cheers Adrian
