Old 14-05-2016, 03:02 PM   #16
Spiyda
Originally Posted by adriantillin View Post
The car is finally running. Looks like the final problem was an air lock in the fuel rail. I have a poorly alternator but that's an easy change out.
Here's a video
https://onedrive.live.com/redir?resi...nt=video%2cmp4
Cheers Adrian
It sounds like drain full of ball bearings ! Lovely !!!
Good to see yet another G13b engined mini (ish) .. must get ours fixed.. just been too busy.
Old 14-05-2016, 08:11 PM   #17
DVO
DVO's Avatar
ECU: Chipped
Congrats, indeed a milstone. In de video indeed it sounds a bit strange, but with mine that was the same (my video was lost in the crash of the site, will put one back on).
Went through the thread again, but I think the spot you put the ECU is not the best. Better put it somewhere inside the car when you have the possibility.
I like the way you put the front engine mounts and incorporating one of them in the mounting of the radiator. On the whole a very nice build, almost looks like that engine belongs there originally.
Dennis
Old 14-05-2016, 11:52 PM   #18
adriantillin
Dennis
Thanks Dennis - sound quality isn't good through the phone and the rattling was the alternator bracket (after I'd removed the offending unit). I have relocated the ECU to under the dash (on advice from others here as well as you).
Really looking forward to getting the car compliance and back on the road now.
Cheers Adrian
adriantillin is offline   Reply With Quote
Old 22-05-2016, 08:50 AM   #19
adriantillin
Well - after 8months and 8 days the G13B powered Moke is back on the road again (albeit a little unofficially). I managed to get the remainder of the wiring finished off and did a couple of other little jobs that needed to be done. Then a quick spin round the block with the eldest as cameraman. The sound quality isn't the best but the car goes and sounds really good. The motor and box are really smooth. Absolutely love the 5th gear.
There's a few things that aren't quite right:
1. The front geometry is miles out. Tracking is somewhere near but caster needs some work.
2. The brakes could do with bleeding again but the booster has made a huge difference.
3. I need to fit a correct temp sender for the gauge as the Suzuki one gives a false reading.
4. The speedo needs recalibrating as its also miles out. Sort of ok to 60 but then reads very low.
Other than that, the car is already for compliance. I'll get on the phone tomorrow ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
I've attached a link to the video is below - not only that we also spotted another Moke (white one) at 24s.
Cheers Adrian
Old 06-06-2016, 03:47 AM   #20
adriantillin
I have feedback from the mod plate engineer. The only thing that needs to be addressed is to fit a dual circuit master cylinder. I've now got one on order, so when it's fitted, I'll be mod plated and all legal.
Cheers Adrian
Old 11-06-2016, 05:20 AM   #21
adriantillin
Suzuki Moke got a wash today (first one in 9 months) ;D ;D ;D
Currently got the wheels and tyres from the black Moke fitted (as these are a bit more legal for the mod plating process).
Cheers Adrian
Old 11-06-2016, 07:48 PM   #22
andyfkettle
andyfkettle's Avatar
Looks great.
Old 11-06-2016, 11:05 PM   #23
adriantillin
Originally Posted by andyfkettle View Post
Looks great.
Thanks mate
Old 12-06-2016, 03:06 AM   #24
nice drive and video,
Old 12-06-2016, 03:09 AM   #25
adriantillin
Thanks - got 100kms under the belt now and all good.
Cheers Adrian
Old 12-06-2016, 03:10 AM   #26
new vids ?
Old 12-06-2016, 03:14 AM   #27
adriantillin
new vids ?
Hopefully heading to local track (Lakeside) in the next month or so - will post then
Cheers Adrian
Old 13-06-2016, 03:29 PM   #28
substitute
substitute's Avatar
ECU: Stock Suzuki
Thumbs up Nice Work
Great Moke - Looks the business
Quietly getting on with it...
Old 13-06-2016, 09:22 PM   #29
adriantillin
Thanks very much - going to try and sort out an under-reading speedo today. Back in my mini days you could take the glass off, remove the needle and replace it at a lower spring tension. Not sure that will work with one of these modern Chinese copies. Let's see
Cheers Adrian
Old 14-06-2016, 10:42 AM   #30
substitute
substitute's Avatar
ECU: Stock Suzuki
Cheers Adrian
I believe you can fit the suzuki speedo into the mini binacle. That's our plan for The Green One
