#31 |
ile look closer when ive cleaned it all up, heres some other stuff, hopefully it will become clearer to me after a little fiddle, lol,i likes a little fiddle i do!!
"yuck ,more like a 3 r2" http://www.youtube.com/watch?feature...&v=tb261HwQNDQ SAY WHAT YOU BELEVE,,BELEVE WHAT YOU LIKE, http://www.youtube.com/watch?feature...&v=3JhaTwP7uuk Last edited by ardonfast; 09-08-2017 at 01:47 PM. |
#32 |
![]() ![]() inside,,
"yuck ,more like a 3 r2" http://www.youtube.com/watch?feature...&v=tb261HwQNDQ SAY WHAT YOU BELEVE,,BELEVE WHAT YOU LIKE, http://www.youtube.com/watch?feature...&v=3JhaTwP7uuk Last edited by ardonfast; 09-08-2017 at 01:48 PM. |
#33 |
cage to dash rail,
"yuck ,more like a 3 r2" http://www.youtube.com/watch?feature...&v=tb261HwQNDQ SAY WHAT YOU BELEVE,,BELEVE WHAT YOU LIKE, http://www.youtube.com/watch?feature...&v=3JhaTwP7uuk Last edited by ardonfast; 09-08-2017 at 01:50 PM. |
#34 |
long shot,
"yuck ,more like a 3 r2" http://www.youtube.com/watch?feature...&v=tb261HwQNDQ SAY WHAT YOU BELEVE,,BELEVE WHAT YOU LIKE, http://www.youtube.com/watch?feature...&v=3JhaTwP7uuk Last edited by ardonfast; 09-08-2017 at 01:51 PM. |
#35 |
Love the long shot, very sexy!
Big potential!
Past; 1992 Rover Mini Spite 1275, 1996 Vauxhall Corsa C20XE. Present; 1994 Suzuki Swift GTI, 1996 Vauxhall Corsa C20XE. I only bow under braking. |
#36 |
Wanks, always leave room for the sleeping arangements,lol, the black bar on the floor that looks like its ment to be there is [infact the removeable rear diaganal,i will skip that and the door bars,ive got short legs and how some peeps acutulay get in there mini i do not know.
#37 |
ECU: OMEX 200 series, ZX6R carbs
Looks good
#38 |
is it true their is room in your car for a 16v engine plus 2 or 3 SeXy bodys and the rest?? are you going to coombe on 29th??
#39 |
Yes it will give the actual total range of movement from full droop to full bump, assuming the spring can deflect that whole range. As you say and I agree the springs are of a high poundage, so bouncing the car is really only deflecting them a small amount. Also the bouncing by hand is not really that same as the car hitting a pot hole, those forces will be higher and quicker.
Whale Oil Beef Hooked! (use Irish accent) |
#40 |
Yes, sounds like the coilover could do with being a tad longer.
#41 |
yes i can see that takeing the spring of i will do this,then see what drops out,thanks good tip..birdman
Originally Posted by Richspec Just been out for a look at mine, as it is now the rose joint is nearly touching the upper most support, i;ve already got the spring quite wound up to gain some height. So thinking about it the coilover is a tad too short, or have i got that the wrong way round? whats this rich^^^ have you found you have a problem?? i can take some pics if you need a referance,??
#42 |
its possibly a problem, but not one of my making! The coilovers are just what it came with, and might need changing by the look of things. No big deal, just expensive and a bitch of a job. When i find out what they are / should be I'll let you know.
eta: Do you have a cutout in the bulkhead so you can remove the top coilover bolt?
Mr 'No patience with dumbass newbies who can't use the search function' XE powered AMT Race frame and Allspeed VTEC Mini builder, (plus some 5 and 8 ports too) ![]() Youtube Channel Last edited by Richspec; 31-08-2012 at 03:48 PM. |
#43 | |
![]() Quote:
#44 |
just looked> no i dont have a hole to get the bolt out] whitch inturn has made me qwestion [again] the integraty of this frame!! i mean im not the shapest tool in the box but cricky THE DIMM aSS frame makers wanna go back to play school
#45 |
Don't dis AMT. Maybe the bolt should have been inserted from the other side before frame went on car? I don't know on that,just a guess, but it would have been an easier arrangement. If it makes you feel better you have acres of room in your engine bay compared to me. By the way I was in your Photobucket account today, so I suppose anyone can access it. The videos and some of the pictures are hilarious. The door hinge tutorial was interesting. Keep up the good work. Shaun...
Thread Tools | |
Display Modes | |
