Old 29-05-2011, 08:58 PM   #1
Add_Gee
Add_Gee's Avatar
ECU: Rover
Default Any suppliers of k-series frame side plates?
Does anyone or any where sell the side plates for mounting an mgf / metro frame to the mini? Also with the shock mounts for coil overs.
If not, does anyone having the drawings for the dimensions?
Also, any suppliers or drawings of the rear braces from subframe to floor?
Cheers!
Old 29-05-2011, 09:37 PM   #2
PHILBISHOP
watsons rally for your side plates think there around 50 quid but there is someone,s build with some dimensions on but hoping in next week to put my build together with them on.Tops for coilovers are easy come by its the bottoms you have to make this week going to take mine to fabricators to see if they can make me a set.
PHILBISHOP is offline   Reply With Quote
Old 29-05-2011, 10:01 PM   #3
cooper_mark
cooper_mark's Avatar
quick search and found................
my beast
Old 30-05-2011, 10:33 AM   #4
Add_Gee
Add_Gee's Avatar
ECU: Rover
That's the pic i was after, cheers Mark.
Also didn't know Watson's did individual parts, useful info thanks.
Old 30-05-2011, 11:12 AM   #5
Add_Gee
Add_Gee's Avatar
ECU: Rover
Anyone have the measurements of the hole centres?
Old 30-05-2011, 04:14 PM   #6
PHILBISHOP
Default spray
make the brackets then when you think you have them in place spray paint through holes then drill best way unless your buying them.
Old 07-07-2013, 10:58 PM   #7
Alburglar
ECU: Preferably Mems3
Send a message via MSN to Alburglar
Awesome, well done for posting that up. Although bolt hole measurements would be useful...
1969 Mini Minus (GRP Body with 4inch body chop) Zcars Rwd R1 engine conversion.
1985 Phoenix Estate (GRP Clubman Estate Body with ugly Reliant Rialto/Robin Hatchback and rear lights) DIY Pg1 subframe K-series conversion.
Alburglar is offline   Reply With Quote
Old 07-08-2018, 10:13 PM   #8
Coaster
ECU: None yet
The bracket shown in the drawing is for a shock mounting, the photos in the rover guide notes on this site show a much bigger and wider mount for a coilover.
Coaster is offline   Reply With Quote
