Old 29-07-2016, 08:11 AM   #46
You say Gaz has offered to make a loom but what is it based on? Personally I'd of used the full car loom and just removed the unwanted wiring. The Allegro can't be much different size wise to the MG ZR.
Planning on using the engine loom as a closed system with just the outputs I need. I'm keeping the Allegro column stalks and switches for lights so won't be using the Zr body loom. Also I'm using a stand alone Acewell dash so wont be using the zr clocks either.
Literally just want to run the engine and have the outputs for rpm signal, fan, fuel pump, oil pressure warning, little red immobiliser light, ignition and start. All my gauges use separate sensors, speedo runs off a magnet to be welded on the driveshaft, separate oil pressure, water temp etc.
Also want a working obd2 port but that's only a couple of wires.
Hoping to use the mems3 fusebox, does it have an mfu? Not seen it on the car yet. I had mems2 mostly figured out then decided to go mems3 lol.
I'll take some pics this weekend but need to figure out which plugs I need that go into the back of the fusebox and also one of the ecu connectors goes into the car loom rather than the engine. If in doubt I'll remove it all.
Old 29-07-2016, 09:23 AM   #47
OK so this is the mems3 ecu Looks like I need a few of the wires from ecu plug2
Also the mfu is under the dash, will recover it and the plugs
Old 29-07-2016, 10:58 AM   #48
A bit more from the internet
Old 05-10-2016, 08:31 PM   #49
B.Bumble
B.Bumble's Avatar
CC: 1396
ECU: MEMS 3 [MGZR]
I am looking to change my SPI to MPi and I have a flywheel and matching ECU to do it. The ECU is model No. MKC104022 and I'm looking for a wiring diagram like the one you are showing on P47 of this thread, the one for the EU3. Where did you find these diagrams? I need one for an EU 1.9. Can you help.
Old 23-10-2016, 03:12 PM   #50
benvvc
benvvc's Avatar
Smile
Found this whilst trawling the net on friday and after a few downloads got my mini running saturday
it may be of use to some of you guys/gals too
http://www.car-manuals.info/rover/
Old 29-10-2016, 10:55 AM   #51
B.Bumble
B.Bumble's Avatar
CC: 1396
ECU: MEMS 3 [MGZR]
Thanks. I saw this one before but couldn't find it again. My PC crashed and when it was re built I had lost all my tagged "Favourites". The diagram on this thread was good as it showed the pins and the attached wires. I'll go back through the diagrams on yours to check but I think injector 2 & 3 are on pin 23 and 1 & 4 are on pin 24.
Old 29-12-2016, 03:02 PM   #52
sousa1981
Default mems2 ecu
can any one please , give me a pin by pin scheme for a mems 2 vvc ecu , it have one red and one black plug... if any one have it please email me to sousa.eu.ricardo@outlook.com
thanks
sousa1981 is offline   Reply With Quote
Old 31-12-2016, 09:35 AM   #53
thanks
I can sort this on Monday as not at my pc at moment.
Old 25-03-2017, 10:46 PM   #54
ZA-J
Ignore me - fixed my own problem!
Old 25-03-2017, 10:53 PM   #55
ZA-J
See above!
