Old 25-02-2017, 06:20 PM   #1
gandolf
ECU: standard ECU
Send a message via Yahoo to gandolf
Default radiator pressure
I've fitted a new 2 core alloy rad to my 1600 .Question is do I remove the pressure seal and spring and leave only the lid seal so the normal pressure expands coolant straight off to expansion tank. Lid is marked 1.1. Thanks for any help.
gandolf is offline   Reply With Quote
Old 25-02-2017, 07:45 PM   #2
That's what I've done on mine, you can get caps without the spring but I didn't see a problem with just removing it from the one I had.
Mines a vvc so I joined the pipe with a t piece together with the hose from the manifold then into the expansion tank, not sure if the 1.6 has a hose from the manifold or not?
Old 25-02-2017, 07:48 PM   #3
Assuming it's a standard Mini radiator cap then you want this.
http://www.moss-europe.co.uk/cap-rad...ng-grc126.html
If you use a spring loaded cap then you'll not bleed the system.
Other stuff to help bleeding is extra holes in the thermostat and remove the "jiggle valve" from the inlet manifold.
All the engines sizes and variants are the same piping so no differences there.
Old 25-02-2017, 08:21 PM   #4
He doesn't exactly need that though, removing the spring from the cap he has will do the exact same job
Old 26-10-2017, 08:45 PM   #5
ZA-J
Sorry for slight hijack, but I assume if removing the spring from the Mini rad, you then plumb the mini overflow into the K series lines? Not sure whether to just plug mine?
ZA-J is offline   Reply With Quote
Old 27-10-2017, 01:05 AM   #6
You Tee it into the pipe going from the intake manifold and the expansion tank. This is how the standard setup works. You can use the Tee piece fitting from all any of these cars.
This also helps with filling and bleeding the coolant.
Old 27-10-2017, 06:34 AM   #7
ZA-J
Ok, thanks. Does that mean I don't need the mg fitting in the top hose which tees into the same header tank line?
Old 27-10-2017, 10:51 AM   #8
EDIT. If it is the connection on a ZR then you won't need that. A ZS has it built into the radiator. Why they had to be different is just Rover being awkward.
The small pipe needs to be kept on a more or less level plain around the engine bay. I had problems with mine when I allowed it to drop below the top of engine. It wouldn't circulate properly.
Old 27-10-2017, 07:07 PM   #9
ZA-J
Perfect, thanks.
Old 28-10-2017, 06:36 PM   #10
twincamtone
twincamtone's Avatar
ECU: Standard MEMS3
Does your alloy rad have a big or small cap? I have a new stainless cap (without spring) here, but it won't fit my alloy rad with the smaller type cap, so you're welcome to it if you want it.
twincamtone is offline   Reply With Quote
Old 30-10-2017, 10:01 PM   #11
ZA-J
Yes, ZR top hose (actually going to use Rover 25 top hose fitting from the scrappy as it fits easier) with 8mm takeoff for header tank. So I can blank the Mini rad takeoff?
Old 31-10-2017, 03:08 AM   #12
Use which ever is the highest point.
