Old 23-10-2017, 11:04 AM   #1
Bigredmini94
Bigredmini94's Avatar
CC: 1800 t
Default Rad temp mini radiator
This has probably been asked before but what water temps are people getting when using the mini rad ?
Sent from my SM-A310F using Tapatalk
Bigredmini94 is offline   Reply With Quote
Old 23-10-2017, 11:45 AM   #2
Mine sits at around 90-95 when moving.
Fan cuts in at over 100 but I canít remember exactly what.
Old 23-10-2017, 11:55 AM   #3
Bigredmini94
CC: 1800 t
Ok thanks kept getting a fluctuating temp found the capillary fitting broke . (Only just had it running) I used a thermometer digital gauge thingy and couldn't get a decent reading. Going to replace the gauge this evening and see what it reads I didn't know if the rad rad causes a high temp then normal but thanks .
