Old 09-10-2017, 05:20 PM   #1
Bigredmini94
Bigredmini94's Avatar
CC: 1800 t
Default Will not start ?
Hello I had the engine running about 8 months ago but I took it out to change my front frame put it all back together and wired it the same but it just will not start got power from ecu to all the engine sensors , it's showing 1.8v at all of them is this low ?
I've gone over it again and again and can't work it out it's a k maps ecu deimmobilezed?
Bigredmini94 is offline   Reply With Quote
Old 09-10-2017, 08:29 PM   #2
Have you connected the engine to body earth strap? what's your actual battery voltage? or voltage at a switched or permanent live?
Old 09-10-2017, 08:41 PM   #3
Also is the engine turning over and not firing or is it not turning at all?
Old 10-10-2017, 06:23 AM   #4
Bigredmini94
CC: 1800 t
I've got 12 v at the permanent live and 12 volt at the switched live, yeah earth is attached also and a jump lead.
I can hear everything power up when ignition is on and cranks over just won't start, checked the ht lead and I am not getting a spark but getting power to the coils ?
I've also replaced the crankshaft sensor in case that was no good .
Old 10-10-2017, 07:42 AM   #5
Is the battery charged ?
Old 10-10-2017, 12:59 PM   #6
Bigredmini94
CC: 1800 t
Yeah tried another and still no luck .
Thinking maybe the ecu ?
Old 10-10-2017, 03:47 PM   #7
Have you tried spraying easi-start in whilst cranking ? If it tries to fire then it's not ignition based so likely to be fuel based. If not then the plugs aren't sparking.
Old 10-10-2017, 07:46 PM   #8
Bigredmini94
CC: 1800 t
Yeah I've also tried that I'm getting power to the coils but no spark checked them with a screw drive up the ht lead I can't see the ecu just packing up ?
Old 10-10-2017, 08:41 PM   #9
Have you got all the ecu earths connected up?
If it was running before it's probably something silly like that, or a loose wire in a plug somewhere, probably need to go round all the connections and check all the wires are right in.
Also instead of sticking a screw driver up the lead, pop a spark plug into one of the coils and earth it then crank the engine and see if there's a spark
Old 12-10-2017, 08:10 AM   #10
Bigredmini94
CC: 1800 t
I think it maybe that, last night I took the engine loom back out to find the oil pressure ground sense for the ecu pin6 broke can this stop the car running as it can't sense a oil pressure ?
Also should I get a constant 12volt feed to the coils?
Thanks
Old 12-10-2017, 09:05 AM   #11
Ecu pin 6 is for oil temperature ground so shouldn't cause a problem, oil pressure is the single wire sensor which goes up to the warning light on the dash. There should be a feed to the coils, it's when the feed is cut that you get the spark so it should be fluctuating between energising and sparking as you crank the engine over. I've never actually had to check one in this way but that's how I understand it to work anyway.
Can you hear the fuel pump prime? When you connected everything back up did you press the lock button on the fob a few times then unlock to re sync the 5as immobiliser module? Sounds like you could still be immobilised and that's all that's needed
Old 14-10-2017, 10:09 PM   #12
Phaeton
Phaeton's Avatar
Have you wired in the inertia switch (always a good idea) if so have you reset it?
Old 15-10-2017, 06:47 AM   #13
Good call!, I've had this trip out when the battery gets re connected
Old 18-10-2017, 05:03 PM   #14
Bigredmini94
CC: 1800 t
Not running immobilizer, it seemed to be a bent pin for the coils /injector connector near the throttle body grapesed me right off but thanks for the help .
Sent from my SM-A310F using Tapatalk
