Old 18-04-2017, 08:25 PM   #1
Lancashirehotrod
ECU: Canems
Default New 16v build
Hi I've just joined this forum but have been reading for some time. I'd like to thank all the regulars for very use full information. I'm nearing the end of my small block Vauxhall conversion in to a fixed steel round nose I will try to get some pictures on.
Lancashirehotrod is offline   Reply With Quote
Old 19-04-2017, 02:09 AM   #2
brave name ladd,, sounds like your confadantly ahead of the game!!
look forward to your stuffs and puff,s and 10 out of 10 for filling in your location box
Old 19-04-2017, 07:20 AM   #3
Welcome to the forum, and like Ardon say's looking forward to your photo's.
Old 19-04-2017, 06:42 PM   #4
Lancashirehotrod
ECU: Canems
Default just learning how to post pictures
just learning how to add pictures to my posts. this should be a picture of my engine bay.
Old 19-04-2017, 06:46 PM   #5
Lancashirehotrod
ECU: Canems
Default x16xe exhaust manifold
that seems to of worked.heres one of my home made exhaust manifold.
Old 19-04-2017, 06:50 PM   #6
Lancashirehotrod
ECU: Canems
zx9r carbs on bogg brothers manifold.
Last edited by Lancashirehotrod; 19-04-2017 at 06:51 PM. Reason: forgot to add picture
Old 19-04-2017, 11:45 PM   #7
nice stuffs
Old 21-04-2017, 03:16 PM   #8
pipsovich
Looking really nice!
Are you using your own subframe or bought?
What ignition system are you going for? Have you sorted the jets for the carbs?
Doing a x16xe at the moment
pipsovich is offline   Reply With Quote
Old 21-04-2017, 04:10 PM   #9
Lancashirehotrod
ECU: Canems
Thanks I'm chuffed with it so far. I've used an allspeed subframe its very well made and I'd say well worth the money. I sent the zx9r carbs and the lower half of my inlet manifold to bogg brothers and they sent back fully cleaned and re jetted carbs on one of there custom manifolds that is a work of art by the way, not just four pipes welded to a flange it is ported to match the triangular inlet ports (x16xel head supposed to flow better according to sbd)on the head side and round on the carb side. And they supplied me with a canems ecu,loom and software to programme. They also loaded on a map to get me started and I'm gonna take it there for rolling road set up soon. Good luck with your build.
Old 25-08-2017, 06:28 PM   #10
Basil
CC: 1598
Send a message via MSN to Basil
How did you make the exhaust manifold?
Basil is offline   Reply With Quote
Old 11-10-2017, 09:49 PM   #11
Lancashirehotrod
ECU: Canems
Hi sorry for the late reply I've been busy having fun in the mini haha. The manifold is a off the shelf corsa 1.8 sxi de-cat manifold that I bought second hand off ebay. The flange was totally the wrong shape so I cut it off and bent and shaped the pipes to fit the new laser cut flange that I also bought from ebay (£30). Then my mate welded the new flange for me. I believe that the headers aren't of optimal length for maximum power for this engine however I was restricted for space between the block and the front panel however It works great it made 150bhp on the rollers and revs freely to my set limit at 7200rpm.
Old 12-10-2017, 07:25 PM   #12
Basil
CC: 1598
Looks very tidy and is very fast I'm sure, good work.
Old 12-10-2017, 08:39 PM   #13
Lancashirehotrod
ECU: Canems
Cheers, it is great fun to drive and still feels like a propper mini I'm gonna turbo it now! I don't know if anyone else has done a x16xe turbo blowing through bike carbs. I fancy the challenge
