Old 25-04-2009, 04:26 PM   #16
cooper_mark
cooper_mark's Avatar
from what i can see looks like he's using standard vaux
vaux TPS and vaux FUEL RAIL...chopped vaux INLET MANIFOLD
my beast
Old 25-04-2009, 05:40 PM   #17
caveman
caveman's Avatar
CC: 2.1
ECU: dta
Send a message via Yahoo to caveman
Default helen
what with bike tb,s didnt think you could do it !
caveman is offline   Reply With Quote
Old 25-04-2009, 05:54 PM   #18
cooper_mark
Default Re: helen
have a read here..........
http://www.16vminiclub.com/forums/vi...asc&highlight=
my beast
Old 25-04-2009, 06:11 PM   #19
caveman
caveman's Avatar
CC: 2.1
ECU: dta
Default helen
that does shed some light on the situation,and im a bit clearer now, but i think you would still need to tinker with ecu though dont think you would be able to run standard
Old 25-04-2009, 07:55 PM   #20
spNOam
spNOam's Avatar
ECU: Tweaked DTA
Engine management will be Megasquirt or Microsquirt (any opinions?) just need to find a 'light' flywheel, if I find one or not that will determine whether I need a trigger wheel or not.
To insanity & beyond!!
Geoff
Old 28-04-2009, 09:39 AM   #21
cooper_mark
have u got any pics of the way u have attached the vaux TPS on to the spindle of the bodeis as i'm doing similar but i have blackbird bodies..
my beast
Old 28-04-2009, 08:42 PM   #22
spNOam
spNOam's Avatar
ECU: Tweaked DTA
Will take it apart on Thursday, will take some picures & try to explain the way I modded the shaft & tps.
Geoff
Old 28-04-2009, 10:05 PM   #23
cooper_mark
nice 1 thnx...only asked as i'm having a few probs with mine.....
http://www.16vminiclub.com/forums/vi...3186&start=160
my beast
Old 28-04-2009, 10:19 PM   #24
Dazzler
Dazzler's Avatar
Make: Toyota
Send a message via MSN to Dazzler Send a message via Yahoo to Dazzler
This is coming on now, when do you think it will be in?
www.preciouswashers.co.uk cleaning equipment and chemicals for your mini!
Dazzler is offline   Reply With Quote
Old 29-04-2009, 05:33 AM   #25
spNOam
spNOam's Avatar
ECU: Tweaked DTA
Hi Daz, story goes like this.....shell is in a shed at the bottom of a hill with no road leading to it, currently there is a pile of sand and bricks in front of the shed door, I'll have to wait for the sand & bricks to be moved then get the lads to carry the shell up the hill into a trailer.....
I'm refurbing all the front end stuff at the moment ready to fit, once I get the shell I reckon about a month to finish.
Geoff
Old 03-05-2009, 04:29 PM   #26
spNOam
spNOam's Avatar
ECU: Tweaked DTA
Second attempt at modifying the exhaust manifold, not a thing of beauty, may be OK once covered in heat wrap, filled it with water (a few times) till there were no leaks, seems workable now. I have enough room for the alternator (need to make a mounting) and I think I'm OK for room for the radiator, anyone using the Cavalier rad?
Also been refurbing the hub assemblies, need these fixed so I can make mock ups of the driveshafts.
Geoff
Old 03-05-2009, 04:54 PM   #27
tiny2403
CC: 2.0
ECU: standaed ecu
Default helen
she's looking good, sorted ya paint pick up on tuesday will transfer it to you via the party animal
tiny2403 is offline   Reply With Quote
Old 03-05-2009, 06:50 PM   #28
spNOam
spNOam's Avatar
ECU: Tweaked DTA
You should come and have a look on the way to 'Sioe Nefyn' tomorrow Subframe's finished, all I need now is the shell.....
Geoff
Old 03-05-2009, 09:29 PM   #29
tiny2403
CC: 2.0
ECU: standaed ecu
Default helen
pm your mobile no to me
Old 04-05-2009, 09:41 PM   #30
tiny2403
CC: 2.0
ECU: standaed ecu
Default helen
top build young man as always, need the body now, go get it and if you need a hand shout
