Old 29-05-2009, 09:13 AM   #16
Muffyvaux
Muffyvaux's Avatar
Removed the interior today and took it down the tip.
Trail fitted bucket seats i bought from Ozium16v. I didn't realise how off centered the seats are to the pedals, or is it just me?!!!
Little pic
Old 14-06-2009, 01:26 PM   #17
Muffyvaux
Muffyvaux's Avatar
Took a break from watching le mans.
Some silicone hose arrived the other day, so made a start on the inlet.
Got the carbs mounted - just need to jubilee clips to secure them in place.
I used some JB weld to fill the injector holes. Just waiting for it to set properly. I will clean it all up and match the ports up later date.
Also got a wiring module so wiring up should be nice and easy (i hope)
Expensive but a great bit of kit.
Old 14-06-2009, 06:02 PM   #18
revingtosh
CC: 1600cc
That wiring module looks a bit sexy!
Where did you get it from?
revingtosh is offline   Reply With Quote
Old 14-06-2009, 06:13 PM   #19
pob
ECU: Vauxhall + superchip
http://www.cbsonline.co.uk/cbs-wirin...mod-1185-p.asp
pob is offline   Reply With Quote
Old 14-06-2009, 07:35 PM   #20
revingtosh
CC: 1600cc
nice...
Gotta get me one of those
Old 15-06-2009, 02:32 AM   #21
Muffyvaux
Muffyvaux's Avatar
yeah it does seem to make the wiring easy - but at a price. its gone up to 90 something now plus vat it was under 90 when i ordered mine!!!
I'll let you know how it gets on when i get a load of cable. way be a month because i got insurance and tax on the micra due soon
Old 15-06-2009, 03:02 PM   #22
2lrMiniVan
ECU: weber alpha tbs
wonder if there is some place cheaper
2lrMiniVan is offline   Reply With Quote
Old 15-06-2009, 03:56 PM   #23
Originally Posted by Muffyvaux
Are you using the Allspeed bulkhead box to clear the gear linkage ?
Old 15-06-2009, 11:01 PM   #24
Muffyvaux
Muffyvaux's Avatar
Not allspeed box just make my own. the hole wasn't cut out in that picture!
Old 18-06-2009, 12:29 AM   #25
Muffyvaux
Muffyvaux's Avatar
The inlet manifold has hardened up nicely and looks really neat!! there is still cleaning up to do on it (like the glue left over from the duck tape)
Also fitted the jubilee clips to hold the silicone hose on - they were a tight fit anyway.
Old 19-06-2009, 09:12 AM   #26
cooper_mark
cooper_mark's Avatar
what did u use to fill the injector hole.....???
my beast
Old 19-06-2009, 11:39 PM   #27
Muffyvaux
Muffyvaux's Avatar
I used JB weld. easy to use, unless you drip the stuff everywhere like i did!
Old 20-06-2009, 11:15 PM   #28
mininut
ECU: Trionic 5.5
If that comes out and dropped into the inlet then you'll blow it up.
M.
Old 21-06-2009, 03:35 PM   #29
Muffyvaux
Muffyvaux's Avatar
yes i have considered that. but it has been used by others with success, and the injector holes taper.
I am very confident it wont fail!
Old 21-06-2009, 03:59 PM   #30
Muffyvaux
Muffyvaux's Avatar
Today i converted the engine from dispak to dizzy! i was going to use megajolt but it seemed alot simpler and quicker just to bosh a dizzy on.
Plus at a later date when the car works i'll go for some injection.
Removed all the cam sensor and coil pack.
chop chop to the dizzy!
now it fits like a glove
i mounted the ignition module thingy on the mounting plate for the old coil pack and the new coil onto the brake cover plate thingy!!!!
