Old 03-08-2014, 03:13 PM   #376
have you taken leave of your sences mr S ?
Old 03-08-2014, 08:42 PM   #377
Andy_S
Andy_S's Avatar
ECU: Megasquirt ... kinda
Firstly my FWD setup is very battered & bent so I'm not happy to continue down the same path only for the same damage to re-appear after a couple of years of abuse.
I have fancied RWD (or 4WD) since the hillclimb clocks showed how fast the 64ft times were. Nearly half a second gain is possible off the start and out of every tight corner due to improved traction.
Finally I have lot of transverse Vaux stuff kicking about so sticking one in the back seems like a cheap way of attempting the RWD thing.
The big question for me is can I still attain fast corner speed with the lump in the rear? The length of the car is it's main problem and so I'm hoping that a bit of roll induced toe, some fat tyres, soft rear susp and an antiroll stiff front will overcome the tendency of the car to swap ends ........ time will tell.
Also at some point I fancy having a crack at a Turbo'd engine so RWD will suit this better.
So 'nope' is the answer to your question
Old 03-08-2014, 08:47 PM   #378
PaulW
PaulW's Avatar
ECU: Megasquirt MX5 Pnp
2nd day no photo's
Old 03-08-2014, 09:02 PM   #379
Andy_S
Andy_S's Avatar
Originally Posted by PaulW View Post
2nd day no photo's
Still just dismantling stuff ....... and finding damaged bits
Old 03-08-2014, 09:20 PM   #380
steve s
Good to here the General is morphing into something else, I'm sure you can crack the rear wheel drive handling, It took us a while but we can drift ours out of corners now and you can catch it before it breaks away, There is loads of videos of rear wheel drive fiat 500 handling great and they are short wheel base,
Looking forward to see how this progress,
Steve.
steve s is offline   Reply With Quote
Old 04-08-2014, 08:37 AM   #381
spNOam
spNOam's Avatar
ECU: Tweaked DTA
Hmmmmmm.......not so sure about putting a great big heavy engine in the back.........
To insanity & beyond!!
Geoff
Old 04-08-2014, 06:07 PM   #382
Andy_S
Andy_S's Avatar
Agreed, although the Vaux VX220 isn't a bad handling vehicle so fingers crossed that I can make the Mini work around the tight & twisties too.
I have a cunning plan for some roll induced toe-in which should reduce oversteer in corners, but i'm not sure if this will become a hindrance in a straight line.
One thing for sure, it's fun to play with a new idea rather than battling with the old one.
Old 05-08-2014, 05:37 PM   #383
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
Originally Posted by Andy_S View Post
Turbo'd
Do that now.
Old 05-08-2014, 08:05 PM   #384
Andy_S
Andy_S's Avatar
Steve.
I'm uber excited by the idea of hanging the rear end out like the 80's icons;
i) Smokey & the Bandit
ii) Starsky & Hutch
iii) Dukes of Hazzard
iv) Cannonball Run
v) Geoff Owen @ Barky
More likely I'll just end up facing the wrong way a lot ........
Old 05-08-2014, 08:56 PM   #385
All good crack mr s , im not sure you have fully convinced yourself yet
Old 06-08-2014, 06:09 AM   #386
spNOam
spNOam's Avatar
ECU: Tweaked DTA
I can't wait
Geoff
Old 05-01-2015, 04:51 PM   #387
spNOam
spNOam's Avatar
ECU: Tweaked DTA
Well?
Geoff
Old 05-01-2015, 05:25 PM   #388
Andy_S
Andy_S's Avatar
DIY & decorating so no garage fun in ages ................ .
Although I just enjoyed a Mini filled Sunday down at Paul's playing with Stella Mk5.
