Old 05-05-2008, 06:49 PM   #31
Hayling mini
Hayling mini's Avatar
CC: 1340
ECU: Haltech
Default How does it feel?
It is really smooth & I love it, noticably much faster than the A series & much nicer. No torque steer at all, I built it for my wife to use & I am sure she will love driving it once the power steering & the Webasto have been fitted. Until then I will enjoy smoking it around in the evening & weekends
The Suzuki feels faster but is suffering from torque steer at the moment, down to suspension setup & the wheels dont help either
I will sort this out next weekend hopefully & then choose which one to use for L2B
Old 06-05-2008, 01:36 AM   #32
mincento
mincento's Avatar
CC: 1390
ECU: Standard Corsa ECU + full loom
Bloody amazing it really is impressive to do it in such a short time, i know its more than half to do with as you said spending the money and buying the whole kit (which isnt cheap) and therefore having everyhting there in front of you but its still a very impressive achievment in such short time
isnt it almost identical to the suzuki on power? i know my 1.4 16v Vaux is slightly less than the GTi motor and i thought the c16's were more than mine?
whens next bank holiday? reckon you could get all the bits together by then for the turbo conversion, we were just on about in another thread how no one had completed a c16 turbo yet and i think your the man for the job?
wayne
mincento is offline   Reply With Quote
Old 06-05-2008, 10:38 AM   #33
Hayling mini
CC: 1340
ECU: Haltech
Default Turbo
Thanks for your comments Wayne, I have been talking to Matt at 16vmini shop about a Turbo. We are looking at how it could be done, the problem would be where to put the Charge cooler, it is so tight in a standard round nose
I cant see the point in bolting on a Turbo system to get 20BHP, it needs to be at least 60 - 80BHP.
Watch this space
Old 06-05-2008, 12:09 PM   #34
http://www.16vminiclub.com/forums/vi...ighlight=turbo
some interesting ideas here
Old 06-05-2008, 01:21 PM   #35
Hayling mini
CC: 1340
ECU: Haltech
Default Turbo
Thanks Oz very interesting, I have seen a picture of a Mini once that had the charge cooler fitted on the front valance. I am going to borrow a selection of bits from a friend of mine & see what can fit where. He earns a living building Jap race engines so has loads of stuff. Then Matt & I will try to come up with something that will work
Old 06-05-2008, 10:59 PM   #36
jimfai
WHAT?? NO AC????
2.0L vtec, custom subby, in a non extended nose saloon. mini saloon with an MI16 PUG driveline. possible zcars saloon underway. 1960 MGA with cologne 2.8L ford conversion.
jimfai is offline   Reply With Quote
Old 07-05-2008, 12:48 PM   #37
Howie
Howie's Avatar
CC: 1598
ECU: MBE
Well done that WAS quick , small block vauxhalls rule ! you'll definately enjoy it.
Howie
C.ider A.ided D.esign (hic)
Howie is offline   Reply With Quote
Old 07-05-2008, 03:13 PM   #38
jasonb89
Send a message via MSN to jasonb89
WELL DONE ! looks awsome
just out of interest if you do do the trubo conversion why are you considering a charge cooler over an intercooler? just woundering as im doing a turbo conversion at the moment but can't decide between the two but a front monut intercooler seems to be alot simpler and has plnety of cooling.
Parts For Sale :(!
jasonb89 is offline   Reply With Quote
Old 07-05-2008, 08:10 PM   #39
Hayling mini
CC: 1340
ECU: Haltech
Default no ac
No Aircon
Its for the wife, she can open the window
Howie I love it, cant believe how well it drives
I am going on the advice of a friend who spends his life bolting huge Turbos onto Jap race engines. We spoke about Turbos for two weeks whilst on holiday in Cuba, his race car develops over 700BHP. He has also offered free charge coolers which really made my mind up
Old 07-05-2008, 08:30 PM   #40
Hoggy
Default re
Is that the pedal box and bracket etc that allspeed sell to move the servo?
Does it fit/work well?
Hoggy is offline   Reply With Quote
Old 07-05-2008, 08:37 PM   #41
Hayling mini
CC: 1340
ECU: Haltech
Default Servo bracket
Hi Hoggy
Yes Allspeed sell it, it works really well, we modified it slightly with more brackets. The bulkhead was flexing so we welded further support in. It saved loads of agro, you will need to move the fuse box up by about 10mm as you cant get the cover off
Old 07-05-2008, 09:53 PM   #42
46
46's Avatar
CC: 2091
Send a message via MSN to 46
I dont suppose you could tell me about how deep the bulkhead box is? I should be able to make my own. Just dont want to make it too shallow.
Mike
46 is offline   Reply With Quote
Old 07-05-2008, 11:50 PM   #43
bodgeit
CC: 998
ECU: Yamaha
how much???
If in doubt, paint it black.
Just add lightness!
Old 08-05-2008, 07:51 AM   #44
BATESPEED
well done guys looks great, what sort of budget do you need to buy all the kit? i know you didnt have time to fabricate any bits in a weekend
"your only young once, but you can be immature for ever" ON THE ROAD!
BATESPEED is offline   Reply With Quote
Old 08-05-2008, 08:02 AM   #45
BATESPEED
i think the 1.6 se would be a great conversion, 100 odd reliable bhp, 100 odd lb ft torque, 5 speed box, all fitted inside a standard looking mini. what sort of performance could you expect? 0 to 60, top speed, speeds in gears , fuel consumption etc? i think it would be a lot better as a daily driver than a lot of the more powerfull conversions. there seems to be quite a lot of people going for this conversion now.
