Old 11-07-2018, 10:07 AM   #31
bobjonah
bobjonah's Avatar
As mentioned before, have you checked the pipes on the master cyl ? The top ( small bore ) goes to the front brakes, and the lower ( large bore ) goes to the rear.
If reversed, you will not be able to bleed them properly, as the system will lock up. You will have brakes, but will be very spongy and won't stop well if at all
Bob Jonah
Old 12-08-2018, 01:44 PM   #32
benvvc
benvvc's Avatar
Cool
Brakes are sorted now guys rear brakes had collapsed behind the drums. And previous owner had drilled a larger hole in the brake pedal causing it to travel a lot before any braking
Big thanks for all of your input
