Old 18-09-2018, 02:16 PM   #16
Cliff Pountney
iB5 was a very common gearbox in small Fords. You will find it in pretty much all 5 speed Fiestas up until the one launched this year. It's also in all 1.4 and 1.6 petrol Focuses. The 2.0 and the XR/ST/RS models tended to use the stronger MTX75. I don't think Ford ever sold the iB5 with a LSD.
Old 18-09-2018, 06:40 PM   #17
I have a collection of these PG1 gearboxes. I have the clutch, flywheel and driveshafts too if interested.
Obviously getting them to you is a massive issue. If you can sort collection then maybe we can sort something.
Old 18-09-2018, 08:43 PM   #18
minimutley
ECU: pinto dizzy, bike carbs
The rs turbo mk4 ran a viscous lsd if I recall?
Just read cliff's post, that scrubs the lsd ib5 then
minimutley is offline   Reply With Quote
Old 18-09-2018, 08:48 PM   #19
Well according to this eBay ad you're bang on!
Old 19-09-2018, 12:27 PM   #20
Coaster
ECU: None yet
Originally Posted by niannorth View Post
I've got one sat doing nothing.
Sorry, spotted one on ebay yesterday and bought it, should be delivered in a few days, comes complete with slave cylinder which is a bit of a bonus
Coaster is offline   Reply With Quote
Old 19-09-2018, 12:35 PM   #21
Coaster
ECU: None yet
Thanks but I found one on ebay yesterday with Make and Offer on it and my offer of 40 was accepted and I bought a pair of drive shafts last night.
The flywheel has me wondering though, as my 1.8 120 engine came fitted with the IB5 box, will the flywheel need changing to suit the PG1?
Colin
Old 19-09-2018, 03:22 PM   #22
Best bet would be to get a pic of your flywheel and possibly find a part number on it for comparison.
Old 19-09-2018, 03:31 PM   #23
Coaster
ECU: None yet
Good idea, I'll have a look at the weekend.
Old 19-09-2018, 04:09 PM   #24
Your flywheel and clutch will need swapping to the PG1 type. Do you know what type of clutch operation you are going to use?
The MG F uses a hydraulic.
MG ZR a cable.
Never heard anyone using the MG ZS sealed system on a conversion.
It's one bolt holding the arm to the box but obviously you need the correct one!
Old 19-09-2018, 08:54 PM   #25
Coaster
ECU: None yet
MG ZR a cable.
I'll go with hydraulic operation, the gearbox has a slave cylinder attached.
Not much flywheel info about on the net, no one mentions different types other than the 1.4 has different sensor trigger holes
Old 20-09-2018, 06:38 AM   #26
The IB5 clutch is smaller diameter. The spines on it are different from the PG1 so you actually cannot use the wrong one even if you tried.
Old 20-09-2018, 11:48 AM   #27
Coaster
ECU: None yet
Thanks, that's saved me some swearing and struggling for sure
Old 21-09-2018, 05:43 PM   #28
Coaster
ECU: None yet
Slight snag, just went to remove the clutch pressure and was confronted with what look like Torqx headed bolts? trip to the shops in the morning, I have more torqx male type than I know what to do with but not a single socket type
I think I'll start another thread on abnormal tools.
