Go Back   16v Mini Club Forums > 16v Mini Sprint > 16v Mini Sprint Chat
Old 10-02-2014, 02:16 PM   #1
D&J racing
Default spaceframe floor
Hi, can anybody help,We wish to build a spaceframed mini. I would like to know what the floor base size is. Just the base to take rollcage and mini body.
D&J racing is offline   Reply With Quote
Old 10-02-2014, 08:27 PM   #2
steve s
This is the dimensions of our spaceframe floor,
Steve.
http://rs1117.pbsrc.com/albums/k586/...62.jpg~320x480
steve s is offline   Reply With Quote
Old 11-02-2014, 04:54 PM   #3
D&J racing
Hello steve, thanks for the drawings, I have measured the inside the shell from inside the sill and the length to where the beam will fit, I rang Bill richards, for the size of the maquire chassis, and with yours I now have three different sizes, please help, I want to order steel. thanks dave.
Old 11-02-2014, 05:07 PM   #4
thers no set size,
that's the good thing about building a space frame it gives you chance to make it your very own,, for the better based on your own knollage and skills,[I hope]
Old 11-02-2014, 09:13 PM   #5
steve s
As Shaun says. there isn't a definite set size, Depends what you are using it for?
Because our mini is track only we cut the floor out at the outer sill lip and boxed it in, See pick, the frame then fits between the vertical section of the inner sill, Because we are using unequal length wishbones and not a beam, Our frame will be a different length to yours,
Hope that helps.
Steve.
Old 23-05-2014, 01:46 PM   #6
Mark D
Mark D's Avatar
CC: lots
My spaceframe is now for sale if your interested, will save you a load of blood,sweat and tears!
Old 23-05-2014, 05:16 PM   #7
big_jim
big_jim's Avatar
And money!!! If you work out how much you think you will spend on building one, then double it!
Buying a done one like marks is cheaper! I know it would have been for me.
Jim
big_jim is offline   Reply With Quote
