Old 26-04-2014, 07:51 PM   #46
cherrybomb
CC: 1598
ECU: dta
This keeps getting better ! Watching with interest so I can change my 16xe for an 18xe
cherrybomb is offline   Reply With Quote
Old 26-04-2014, 08:15 PM   #47
MarkGTT
MarkGTT's Avatar
ECU: MBE
Let me know if you have any specific questions that I don't cover here - I'm happy to help if I can buddy
Old 27-04-2014, 10:49 AM   #48
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
What sort of bhp do you think you'll end up with from this conversion Mark?
Old 27-04-2014, 12:19 PM   #49
MarkGTT
MarkGTT's Avatar
ECU: MBE
170 ish I guess, it will have a full RR set up once it's running so will post the figures up.
Old 04-05-2014, 02:58 PM   #50
MarkGTT
MarkGTT's Avatar
ECU: MBE
Steady progress being made - Managed to get the front hubs and discs etc mocked up today - all fits, callipers might be a few months off yet - looking at the SC mono block 4 pots.
Old 22-06-2014, 08:55 PM   #51
MarkGTT
MarkGTT's Avatar
ECU: MBE
Not had much spare time over the last month but managed to get a few hours garage time when I could.
I now have a rolling shell, makes things a bit easier - also got it out in the day light for the first time since the respray.
Linkage and itbs now in place
Took much longer than expected to fit the bonnet and grill, but I'm happy with the panel gaps and fitment now.
Might start on the brakes next if I can decide what calipers to opt for.
Cheers Mark
Old 22-06-2014, 09:25 PM   #52
wee man
wee man's Avatar
quality build. impressive
12.71@108.44
Old 22-06-2014, 10:09 PM   #53
mini_mad69
mini_mad69's Avatar
ECU: bosch jetronic
How was it you cleared the sump clearance on the allspeed frame? This was the main thing holding me back with my z18xe conversion.
Slowly building a z18xe allspeed mini
Hopefully running in 2013 some time
mini_mad69 is offline   Reply With Quote
Old 22-06-2014, 10:20 PM   #54
MarkGTT
MarkGTT's Avatar
ECU: MBE
Im using a 1600 sump, with a custom oil pick up.
I have a mate who's done a similar conversion in a nova.
Old 22-06-2014, 10:29 PM   #55
mini_mad69
mini_mad69's Avatar
ECU: bosch jetronic
I did notice that the spare c16se sump I have has the same bolt pattern, and think I should be able to cut down the standard pickup.
Thanks, looks like a clean build!
Old 23-06-2014, 05:02 PM   #56
Dubaidaz
Dubaidaz's Avatar
CC: 1598
ECU: MBE 9A4
Looking good bud.
What you doing about the exhaust and radiator? Two expensive items in my build!
Old 23-06-2014, 06:59 PM   #57
MarkGTT
MarkGTT's Avatar
ECU: MBE
Cheers Darren, exhaust is being custom made as we speak.. I don't know the final cost yet!
Radiator wise I'm considering a number of 'off the shelf' items, favourite so far is from a Honda Civic however I keep changing my mind.
Old 24-06-2014, 05:09 AM   #58
Dubaidaz
Dubaidaz's Avatar
CC: 1598
ECU: MBE 9A4
Radiator wise - nothing fitted, all too big either depth or width.. Except MPi rad which was deemed too small. So that was custom made.
And......... same for the exhaust really. The SBD headers (from their blueprint) were so long to the first collection point (4 into 2) we hardly had any room between the block and grill and the Mini being only 10 feet long, hardly any scope to 'lose' the required length of each header. So we ended up stacking the pipes and modifying the sump. Now I'll need an oil cooler to stop the sump oil boiling.
I love the colour of your car. My car is British Racing Green with a white roof (standard Rover Mini Cooper) and although I like my existing colour yours is beautiful. So if I paint mine the same as yours I'll be guilty of copying you! My mate just had a feature in a Mini mag (can't remember which one) and he also went green with a white roof. It's the way to go.
Did the same folks shotblast the car as well as paint it?
I wanted to know how much shotblasting is since I think if the shell is fairly solid (mine is) this may be the best way forward for me. I think the people I have in mind to paint my car don't do shotblasting.
Anyways top job bud keep it up.
Old 24-06-2014, 07:30 PM   #59
MarkGTT
MarkGTT's Avatar
ECU: MBE
Thanks buddy - Shot-blasting was arranged by the same company that did the paint.
I'm hoping I can find a suitable radiator without going down the custom route.
Old 28-09-2014, 07:33 PM   #60
MarkGTT
MarkGTT's Avatar
ECU: MBE
Small update, I'm not really against the clock with this so just taking my time and doing odd bits when I have free time.
Not a lot to show, but I've run the loom through the car and have the back end assembled bar the tank etc. 70's rear lights, black lamp - nothing revelotutionary but neat and clean looking.
I've also built the doors, glass, winders and a set of downton mirrors in brushed alloy. My guess is they won't be much use but I love the look.
Front headlights are on and I've done some other small jobs at the front end. The biggest addition is the custom exhaust manifold and link pipe, it really is a great job - after a lot of discussion measuring and research I'm well happy.
A few pics.
I might start the wiring next, depends if I can decide what instruments to go for.. This is the mess behind my last dash I need to sort - that should be fun
Cheers Mark.
