Old 01-09-2018, 10:34 PM   #556
Hi,
I have spent just 1hr today in my garage.
Looks OK I think.
My top speed should be 130-ish with more stream line than a standard Mini.
I think I will be having brown pants with that sort of speed!
Old 02-09-2018, 05:23 AM   #557
Brown and more brown !
Old 02-09-2018, 06:43 AM   #558
Looks great! I forgot all about those gauges you have on top, they’re brilliant
Old 10-09-2018, 06:59 PM   #559
Hi,
Over the weekend, I have worked on few wirings and others.
I have been working on mk1 Swift Gti wiper motor with it's switches but with Citroen AX single wiper.
https://www.facebook.com/atsushi.kim...92749604557241
After that I tidied up wiring under the scuttle panel.
Then weld in actual scuttle panel to the rest of body.
I can now work on actual front screen to be fitted!
Old 30-11-2018, 11:02 PM   #560
Hi,
While I'm getting my roll cage made, I have been busy making my bonnet.
I had a steel bonnet with air vents and so on but I found out that it will cool my radiator but send warm air into my engine.
So I dug out my GRP bonnet which has a Metro vent in but I wanted to fit a RS turbo vent just behind my radiator.
First I cut out hole for a turbo vent to fit and take out a Metro vent
Then I used GRP patty to fill the gap and reused what I have cut out for the hole left with Metro vent.
I will be sanding down and use filler to make it neat and flash.
Old 01-02-2019, 11:24 PM   #561
Hi,
Not much but I have managed to fit my instrument panel in with stiffener!
Old 05-02-2019, 11:45 AM   #562
Link is not working
Old 16-03-2019, 10:57 PM   #563
So during last month, I have been waiting for my mate Dave to bend me roll cage CDS tubings.
He is a busy man but he managed to make it for me.
Mean while he was busy making me it, I fitted my rear boot set up.
Then all the fun started with my roll cage!
Gaset I made and welded in with my cage.
I can start building my dash then wiring!
Old 02-04-2019, 09:15 PM   #564
Looks sturdy
Old 12-04-2019, 10:00 PM   #565
Hi,
I'm working hard to get my on the road for Mini 60 IMM this year....
I have managed to get most of my instrument working.
Here is my rev counter working.
Then I have started to work on my doors and windows.
All of my indicator is working also!
After recommendation from my mate Dave, I will be fitting LED head light bulbs. I was going to fit HID but LED will be much simpler!
Old 13-04-2019, 04:40 PM   #566
Great progress Atchi, keep the momentum and you’re done in no time
Old 22-04-2019, 09:11 PM   #567
So, I have been busy doing as much as I can in little time I got before this summer.
First of all, I fit my driver side door.
Then I bought LED day light bulbs.
I needed to re-wire as I made mess 5 years ago. But finally, I got this!
Very bright but you can tell in day time.
So, I thought I shall try later!
All I need to do is only 1 side of A4! but my list id very small writing for the MOT!
