Old 30-06-2018, 01:24 PM   #31
Yes , I build my minis so nothing is preventing other things from moving , that's just something to consider , that's open to your interpretation ,
I think if a mini speshalist is letting such dangerous things go it's top priority to shout loud !!!
Old 30-06-2018, 06:07 PM   #32
pipsovich
I have tried to do that as well, but building everything so that the subframe could be removed, that is beyond my capabilities
Hopefully they Will take this seriously, since it is dangerous.. What is worst case, steering completely lost? Maybe i could try to shim it in place, but it wont be properly done that way....
pipsovich is offline   Reply With Quote
Old 30-06-2018, 10:37 PM   #33
No it won't be lost, you can't brake that if you wanted to,
But I don't think that's the point,
The point is(I feel) a major suplyer should not/never send out some goods,. Not fit for purpose!
Let's say, that I could forgive a faulty horn push or a bent bumper! The 2 aren't the same,
I don't think you should bother trying to shim/mend it in any
Way, see what they say,
Old 09-07-2018, 07:39 AM   #34
pipsovich
Still no real answer from minisport.
They told me that they are working on it, and trying to find shims so that i can shim it in place... which to me does not seem like a good solution, arent the play/resistance of steering supposed to be measured accurately in a bench to know that the rack is correctly shimmed? Maybe it could be done in place, but i dont even have the tools for the job.
Old 09-07-2018, 07:48 AM   #35
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
MiniSport don't have a great reputation for customer service to be honest.
Sent from my F8331 using Tapatalk
I've got 3 long studs in my hand.
NudgerSS is offline   Reply With Quote
Old 09-07-2018, 02:06 PM   #36
That's exactly what they would say , they just hope you will say yes!
"We will try to find shims to send to you" that's not exseptable,
By our trade law if you sell a itam that's not fit for purpose
We have to replace it or refund the customer,
That's loosely speaking, I don't ring and complain about
Things normally, but I would be upset by this,
They should take it up with the people who sold it to them,
Old 10-07-2018, 02:50 AM   #37
250ptm
250ptm's Avatar
ECU: odb1
Pipsovich,
IF Minisport can’t help there is a procedure for adjusting the rack preload from Haynes manual, which should remove the play that you see in your vid.
No mention of special tools required.
For shim stock check out E-bay.
From your vid it looks as though the adjustment should be accessible from under the car.
From Haynes: 34. Fit a new O-ring seal to the damper yoke
and place the spring in position. Add shims
equal to the gap measured between the cover
plate and housing plus 0.05 to 0.13 mm. Refit
the cover plate and tighten down the bolts.
Turn the pinion through 180 in each direction
from the centre and make sure there is no
tightness or binding.
It only took me 3 years to reach 100 posts and become a senior member!
250ptm is offline   Reply With Quote
Old 29-07-2018, 09:02 PM   #38
pipsovich
Car is registered and road legal in sweden! Have drived it a lot, here are some Nice pictures from a little Track evening.
28 degrees celcius and sunshine. Using modified China mpi alu radiator, SBD 75 degrees thermostat, and a China 9 row oil cooler. No issues even on the track!
Old 29-07-2018, 09:03 PM   #39
pipsovich
And yes, minisport sent me a replacement rack, which i Will fit at some point.. As of now i have shimmed it in place, it works for now.
Old 29-07-2018, 09:28 PM   #40
Good they sent you new steering rack, good that you are
Useing the mini ,good, good,
Old 30-07-2018, 12:31 AM   #41
250ptm
250ptm's Avatar
ECU: odb1
Im interested to know, did the shimming eliminate the play in the rack ?
Old 31-07-2018, 08:39 AM   #42
pipsovich
Hello! Yes, it did, but i dont feel good about it anyways.
Old 09-04-2019, 07:23 PM   #43
pipsovich
Some little upgrades to the mini!
I have installed a quaife ATB diff and a 4,0 kg flywheel from sbd engineering, along with a new flat type clutch and clutch cover. It was a really good upgrade from the very heavy stock flywheel, and the diff... yes it pulls better out of corners now i can tell you, will be real interesting to test it on the track!
Was a bit of work to replace all the bearings and so on but fairly smooth operation anyways, to get the diff in it!
Now i need to fix a better inlet (have a look at the photo. this is a "powerbox"...) and raise the rpm limit to 7400-ish (i have arp rod bolts)
Im in the process of making a 3d-printed plenum with built in bellmouths that hopefully will work!
