Old 14-12-2014, 10:45 PM   #76
minion
minion's Avatar
ECU: mems 3
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
minion is offline   Reply With Quote
Old 15-12-2014, 11:44 PM   #77
minion
minion's Avatar
ECU: mems 3
bottom arms,, right I am thinking there go have to be adjustable
will modifify pins to suit
or am I better getting rose jointed bottom arms and just weld in a plate and drill a hole, these will need tapered spacers but just wondered how many guys use these in there road cars and what does mot tester think?
I think the second will be an easy option if good and legal
also thoughts on rose jointed tie bars?
Old 16-12-2014, 09:12 AM   #78
minidarren83
minidarren83's Avatar
It's personel choice really they need to be adjustable for a start both bottom arms and tiebars but how they mount weather it be standard type or rose jointed I don't think makes any difference for a road car
minidarren83 is offline   Reply With Quote
Old 16-12-2014, 05:02 PM   #79
harrison541
If they're rubber mounted there's a certain amount of flex, where as with rose joints they're a solid mount, so rose jointed would be best for a track car.
As above, for a road car I don't think you'll notice the difference. I'll be using the rubber based mounts in mine.
Old 04-01-2015, 09:52 AM   #80
minion
minion's Avatar
ECU: mems 3
Default build
not been in garage much, well apart from trying to tidy it all up,gotta get my peach in gear and get stuff ready to go back to work the morn then I will be out in garage later to make some progress I hope
get some new engine mounts sorted etc
still deciding on bottom arms yet
Old 04-01-2015, 11:16 AM   #81
rose joints are for race cars - all the shock and vibration will be transferred into the car and a large pot-hole could damage them. I believe they also wear out pretty fast on the road
Old 04-01-2015, 01:25 PM   #82
minion
minion's Avatar
ECU: mems 3
Umm looks like I might just go for adjustsble bottom arms with Bush's.
Vibration doesn't worry me as subframe is solid mounts already but don't like idea of them not lasting and having to change them n reset geometry of suspension every time, I just thought of rose jointed arms to save modding the bottom pins.
Just had a raid of the goodies bin and found some new orange bushes for bottom arms so will fit them and standard arms to get the project moving again
Old 04-01-2015, 10:29 PM   #83
minion
minion's Avatar
ECU: mems 3
Default gearbox mount
made up this using land rover style mount to try and keep everything nice and small
[IMG][/IMG]
[IMG][/IMG]
what do you guys think?
was looking at the front thinking if I put the zt manifold on with turbo above gear box I can get a rad in front of block?
Old 05-01-2015, 12:53 PM   #84
Not sure that using the land rover cotton reel mount like that will last very long, but you never know. At least you have the angle built into the mount. I guess it depends upon all the other mounts and how they stop the engine and box from moving around.
Old 13-11-2016, 08:21 PM   #85
minion
minion's Avatar
ECU: mems 3
Am back,,been in hibernation I think and woke up at wrong time of year coz the garage is bloody cold and trying to find where I left my bloody mini ,am sure I got further than the pics?
Ps hello everybody
Old 13-11-2016, 09:59 PM   #86
boom jock!! wake the fook up,
Old 14-11-2016, 11:10 PM   #87
minion
minion's Avatar
ECU: mems 3
am up...now pass the caffeine not that groggy cider
Old 16-11-2016, 01:14 AM   #88
head south and try some, whats new in the life of ross?
Old 18-11-2016, 12:11 AM   #89
minion
minion's Avatar
ECU: mems 3
be careful or i might just do that and end up drinking your stash dry .
life in general,lows and highs and trying to run a steady business.also there is now a mrs minion lol which took all my spending money and beer tokens. my mum passed away sadly so had to clear out,and all junk ( amazing what you collect and keep ) from spare garage got piled in current one on and around the mini to the point i forgot i had one......so my 3 month deadline is looking more like maybe 3 years and am sure it might be on the road but not finished .
seems you guys have all been doing a fine job to make up for lack of mine
frost it,,,,wheres the cider?
Old 05-01-2019, 08:10 PM   #90
minion
minion's Avatar
ECU: mems 3
update,,,finally found my mini,got garage cleared out, well kinda
got to strip a mg tf so that poked me in right direction, will try and keep this updated
quick look to remind me where i got to,,,no where close to finishing
to do .
finish braces for sub frame
brakes,pedal box,pipes and calipers (need master)
clutch pipes
tidy electrics
gear linkage
mate the two exhausts
then body work,,,,after last attempt i might try the Agoaty method?
finally got the heater repaired and built up again,no pictures as well all know what they look like.
away to enjoy the crisp garage air now
