Old 27-06-2013, 05:34 PM   #31
Kaison
Kaison's Avatar
Tahiti blue!
I only bow under braking.
Old 27-06-2013, 06:58 PM   #32
Black Tulip!
Old 26-09-2013, 11:37 PM   #33
Kieranzxt
It's looking like it's going to be Purple. (Highland Purple to be precise)
Kieranzxt is offline   Reply With Quote
Old 04-08-2017, 03:51 PM   #34
Kieranzxt
Just to update this, it ended up Pageant blue and a 1.8!
Old 04-08-2017, 09:41 PM   #35
will16
will16's Avatar
ECU: K Maps 170
That looks gorgeous! Are they still the dolly sprint wheels?
Old 05-08-2017, 12:17 AM   #36
Kieranzxt
Yes, Dolly sprint!
Old 05-08-2017, 02:25 AM   #37
nice job >dad of adam,, whers the middle? lol
Old 05-08-2017, 05:19 AM   #38
Great colour. That has to be about the neatest extended front valance I've seen. How did you do, and is it fixed or removable?
Old 05-08-2017, 06:37 AM   #39
Kieranzxt
The subframe front crossmember was cut out and replaced with a straight bit of 50x20 box section. I then straightened the front valance to sit against it on little spacers.
The valance is spit, passenger side fixed, drivers side is removeable to enable access to the alternator and drive belt. The little box in the removable panel, next to the number plate is clearance for the alternator.
When I fitted the Janspeed manifold, I had to make the centre of the crossmember removeable, otherwise the exhaust couldn't physically be fitted!
Spec is as follows:-
1.8 K series, 160 bottom end
DVA non vvc head with the oversize valves (in standard enlarged seats)
Piper 633 cams
38mm motorcycle carburettors (Yam thunderace)
Megajolt ignition
Janspeed exhaustmanifold, 2" twin box mini system
MGF PF1 gearbox with type B Torsten diff
Old 05-08-2017, 06:41 AM   #40
Kieranzxt
It goes quite well, sounds like this
Old 06-08-2017, 03:42 PM   #41
Rob180bhp
What a lovely looking car, more build pics are needed
Sent from my SM-G928F using Tapatalk
Rob180bhp is offline   Reply With Quote
Old 06-08-2017, 06:53 PM   #42
Engine spec sounds awesome but I can't get your video to play
Old 06-08-2017, 09:39 PM   #43
Kieranzxt
Try this
https://youtu.be/4zEqUQw-nzM
Old 06-08-2017, 09:45 PM   #44
Kieranzxt
This was very wet practice!
https://youtu.be/4boucg1aHe0
Old 07-08-2017, 04:51 AM   #45
