Old 07-05-2013, 07:32 AM   #136
Artstu
Artstu's Avatar
CC: 1275
ECU: Nissan Micra
Originally Posted by matt View Post
Yes was there. What was you in only saw a mini pickup and a 4x4 mini there?
I didn't go this year. I saw the photo on Pistonheads. Perhaps I'll make it next year in the Midas.
http://www.pistonheads.com/gassing/t...ow+thread+2013
Artstu is offline   Reply With Quote
Old 08-05-2013, 08:40 PM   #137
matt
matt's Avatar
ECU: Mems 3 Z&F
Abit of a interesting update.
My dad moved the exhaust cam timing on the van yesterday. I had calculated that 1tooth on the exhaust cam pulley was 7.4 degrees.
Now the head on this engine has had a fair old skim so the standard cam timing was retarded. (Don't know by how much thou)
But he says that a massively noticeable difference can now be felt. Feels way more lively and feels more torquey on part throttle acceleration.
Its abit of a bodge but will be taking it back to the rollers to see the difference, but hopefully should be up to stock power now.
Rover no show and all go!!!!!
Old 08-05-2013, 10:39 PM   #138
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
about 1 month ago i figured out my motor was in the same boat. both intake and exhaust cams were 2.5deg out (5 crank deg) from 0. not sure about rovers but general rule of thumb for b series is for every .001" skim = 1 degree retarded (crank). i also noticed a boost in low end power.. keep us updated on how the timing helped with the hp.
Old 09-05-2013, 04:50 PM   #139
matt
matt's Avatar
ECU: Mems 3 Z&F
Interesting that. I've had this problem to on a T16 engine I built. But I guess what you say above will be roughy the same for any engine.
Is .001" a thou ?
Old 09-05-2013, 11:31 PM   #140
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
Yes.
Old 07-05-2017, 04:45 PM   #141
cooper_mark
cooper_mark's Avatar
Saw this today @ himley looked mint
my beast
