Old 24-02-2010, 04:07 PM   #106
1WHEELKING
1WHEELKING's Avatar
loving the right side tank!! keep the pictures coming!
Nathan
1WHEELKING is offline   Reply With Quote
Old 24-02-2010, 04:30 PM   #107
Mini_Filip
Mini_Filip's Avatar
ECU: JDM P73
aaaw, very nice! Is this one for me mate?
was it a headache to make it?
Mini_Filip is offline   Reply With Quote
Old 24-02-2010, 04:39 PM   #108
Mini Vlatko
Mini Vlatko's Avatar
If you still want made one...
Took me 3-4 hours to this state...still needs a lot of welding...
Old 25-02-2010, 03:18 PM   #109
Mini Vlatko
Today I finished construction of the tank but it still needs to be weld properly...
I also relocated exit pipe because it would be seen while trunk is opened...and I removed fuel sender hole...it's not needed here
I made small slope on the bottom to make battery more reachable...I know there's no bat box here but it's not for my car
Old 27-02-2010, 08:13 AM   #110
Mini Vlatko
Zinc plated and ready for powder coating
Old 27-02-2010, 10:52 AM   #111
Mini_Filip
Mini_Filip's Avatar
ECU: JDM P73
Jummie! very nice! I am so happy with the design and the strenght of the beam!
Old 27-02-2010, 10:54 AM   #112
MiniMadGreg.
MiniMadGreg.'s Avatar
ECU: P28 Neptune rtp
Send a message via MSN to MiniMadGreg. Send a message via Yahoo to MiniMadGreg.
How much has that set you back all together making it and wot-not?
.... You was only suppose to blow the bloody doors off ! ....
MiniMadGreg. is offline   Reply With Quote
Old 27-02-2010, 11:08 AM   #113
Mini_Filip
Mini_Filip's Avatar
ECU: JDM P73
This is the prototype of the beam that we plan to produce. It is going to be tested on this car and we will see if it needs any more tweaking. The idea is to be precisely fabricated so you don't have to bother with it while fitting, zync plated and powder coated in the color of your choice and to have very friendly price compared to other beam axles on the market. It will be cheaper to buy this beam then to get involved in building one for yourself.
Old 27-02-2010, 06:18 PM   #114
cooper_mark
cooper_mark's Avatar
Originally Posted by Mini Vlatko View Post
beams looking great and the tank
only thing is the sqaure tubing u have used to bolt to the original holes on the healboard
have u Reinforced inside as u might find that what when u tighted the bolts they might squash the tubing....
my beast
Old 28-02-2010, 08:34 AM   #115
Mini Vlatko
Not to worry mate
At one point I also noticed that and then I added sleeves in...the ones that goes through standard Mini stabilizer bush
Maybe you can se that the hole is closed...that's because the sleeve is inserted and all welded
I'll take more pics when it gets powder coated...
Old 02-03-2010, 03:21 PM   #116
Mini Vlatko
All powder coated and ready to be installed
Old 02-03-2010, 03:33 PM   #117
Mini Vlatko
Welded tank...
Now I have to find proper way to cote it from inside to prevent corrosion...
Old 02-03-2010, 10:57 PM   #118
Quadra
Quadra's Avatar
Frosts do a tank sealer.
http://www.frost.co.uk/item_Detail.a...oductName=Fuel Tank Sealer (US Quart, 946ml) &catID=25&frostCat=Tanks&frostSubCat=&subCatID=
Quadra is offline   Reply With Quote
Old 03-03-2010, 07:23 AM   #119
Mini Vlatko
Cheers for that but I'm worried about that little plastic thing right on the feed pipe...some sort of filter to prevent sucking debris into fuel line...
If I pore any kind of tank sealer in I think that will get clogged...
Old 31-03-2010, 04:14 PM   #120
Mini Vlatko
Small update
I collected all parts and now I was finally able to assemble my calipers
All parts were zinc plated and then powdercoated...
I'm very pleased with result
