Old 09-01-2018, 07:02 AM   #1
mearcat
CC: 1331
Make: Toyota
Default Gear cable routes & firewall sealing
I have to route the gear shift cables for my Toyota 4E-FTE from the cabin into the engine bay. Due to the angle of the cables through the Mini firewall, the cables are no where near perpendicular to the firewall so using a standard split grommet, they don't seal well. I'd like to get ideas on how others have sealed any cables through the firewall. Any photos would be nice too please. Thanks
mearcat is offline   Reply With Quote
Old 09-01-2018, 12:40 PM   #2
I don't have any pictures but do remember seeing steering rack gaiters being used for this. Obviously a ring would need welding to the firewall but I'm sure that isn't too hard.
Old 10-01-2018, 08:02 AM   #3
Kam
Kam's Avatar
Yeah stretch the steering gaitor, pass it through then cable tie each end to the gear cable
If you want to be really posh use one of them small gearstick gaiter housings with a chrome surround (cabin gearstick housing) if itís gonna be on show and you are wanting a blinged up bay
Or have a look for stepped grommets
Hth
Old 29-01-2018, 03:42 AM   #4
mearcat
CC: 1331
Make: Toyota
Originally Posted by Kam View Post
Yeah stretch the steering gaitor, pass it through then cable tie each end to the gear cable...
That sounds like a perfect idea! Thanks
Old 06-03-2018, 01:24 AM   #5
mearcat
CC: 1331
Make: Toyota
Here is the result of using the steering gaitor.
I machined a ring that mounts against the firewall
The gaitor then slips over this ring
Tags
firewall grommet
