Old 27-04-2008, 09:05 PM   #1
l_jonez
ECU: Megasquirt and ITB's
Default BMH shell build [standard length]
After many months/years reserching and saving up we've finaly started our B16a2 vtec build. We are building our own frame and will be keeping the front as it is
The mini
a 1988 city which we reshelled a couple of years back into a new BMH shell
The civic
93 civic vti
Our frame & jig
started on theses today made a jig which uses the normal subframe mounting points. After a couple of hours we had the jig pritty much finished, just needs fome legs welded onto it to obtain the correct height.
once the jig was done we weldded in a brace across the towers and then set about removing the tie rod brackets so that they can be re used.
will try update with any progrress as oftern as posible, will also be putting my pics here http://s252.photobucket.com/albums/hh21/lrjonez/vtec/
all comments & veiws welcome
Old 29-04-2008, 06:56 PM   #2
l_jonez
got the civic booked in for an mot tomorro because apparently you need one before selling a private plate.
As far as we know there is nothing needed to pass so as soon as it gets back the strip will begin
Old 01-05-2008, 07:47 PM   #3
thomsonminis
Default private plate
You dont have to have the car mot to remove the plate, if it was sorned and the mot and tax wasnt out for a year then you can remove plate did it with my mini, think this info is correct.
flat oot like a deuks fit!!!
thomsonminis is offline   Reply With Quote
Old 01-05-2008, 07:51 PM   #4
l_jonez
Default Re: private plate
well its been moted and the plate has been sold now
Old 04-05-2008, 10:04 PM   #5
l_jonez
well today we started striping the civic and now the engine is ready to lift out, it would have been done today but we forgot to take the lifting straps with us as the car is being kept a few miles away
Old 07-05-2008, 10:33 PM   #6
l_jonez
hit a dead end with the frame build due to a lack of engine so yesterday it was removed
also started to figure out how much has to be cut etc
Old 12-05-2008, 10:31 PM   #7
l_jonez
removed the loom from the civic today, didnt realise how big it was
started to cud it down and managed to cut thru one of the ecu cables and now i cant find the cut off end
Old 17-05-2008, 07:54 PM   #8
l_jonez
spent a few hours on the loom today and excpt for 2 or 3 wires its done, still needs to be re-bound tho
Old 02-06-2008, 05:47 PM   #9
DarrenW
Guest
Posts: n/a
Hows it all going, any progress ont he frame or wiring
Old 02-06-2008, 06:37 PM   #10
l_jonez
havent made any progress for the last week or so , as we had to take the other mini of the road due to brake failure + blown head gasket and theres not quite enough room to carry on with the frame.
hopefully tho if mini sport can be trusted i should have my new master cylinder and head gasket tommoro which means the mini will be back on the rooad by the evening and we can carry on.
the wireing is pritty much done just have to fit a fuse box in the car and connect every thing up and pray it works
will up date with some pics of the frame once we get the mini out of the way.
Old 08-06-2008, 09:38 PM   #11
l_jonez
not realy much of an update but today we bought a old shell
its gonna be used for the dummy build so we can ensure every thing fits and work before taking the mini of the road
Old 26-06-2008, 10:37 PM   #12
Pete_H
Pete_H's Avatar
CC: 1333
ECU: megasquirt
Send a message via MSN to Pete_H
any updates?
you should put the engine in that van you have got
My suzuki build diary
http://www.16vminiclub.com/forums/showthread.php?t=4427
Pete_H is offline   Reply With Quote
Old 29-06-2008, 03:46 PM   #13
l_jonez
Sadly no updates, did manage to get the frame into the shell which showed up a few clerance issues which will have to be sorted,
the build is on stop for now as the van is being moved into the garage for some tin butchery to take place
Old 15-08-2008, 08:34 PM   #14
l_jonez
after a couple of months break i managed to do do a little be more on the frame today as i have run out of gas and cant carry on with the van
found out today whilst on full lock and the suspension at its lowest ( resting on bump stops) the passanger wheel just touches the frame
its that close that if i had been using slighty warn tyres and not brand new ones it wouldnt have touched
so the frame has been modifyed and we have ample clerance, got a few more modifications to make, maybe tomorrow and then i'll try get some pics up
Old 15-08-2008, 08:53 PM   #15
BATESPEED
mini's looking good........ and you'r making good progress, keep up the good work
"your only young once, but you can be immature for ever" ON THE ROAD!
BATESPEED is offline   Reply With Quote
