Go Back   16v Mini Club Forums > 16v Mini Sprint > 16v Mini Sprint Chat
Old 31-03-2008, 06:46 PM   #1
Andy_S
Andy_S's Avatar
ECU: Megasquirt ... kinda
Default Brake Mods for Elvington
Ok so here's some bits I did recently.
Timing Splitter & Towing Eye:
2.5" Stainless Exhaust System (Made by me)
and a choice of tailpipes ........ one for noisy & one for scrutineering
I've got the Fire Extinguisher on order, so I think that's everything:
Although I really fancy one of these (the one on the right):
[/b]
Old 31-03-2008, 06:58 PM   #2
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
looking beefy! Better top end?
//marcus
Old 31-03-2008, 07:15 PM   #3
Smurfy
Smurfy's Avatar
Send a message via MSN to Smurfy
Looking good
Smurfy is offline   Reply With Quote
Old 31-03-2008, 07:26 PM   #4
garyshoose
garyshoose's Avatar
CC: Sold
ECU: Honda
Like it Andy. where did you get the inline silencer, It looks like a slip on job? just wot i need as I'm running out of paracetamol. Mines got an upswept oval jobby for that "full race note" according to the reciept. It's way too loud. My neighbours got a Bonnie with straight through and it doesn't even come close
garyshoose is offline   Reply With Quote
Old 31-03-2008, 07:41 PM   #5
Andy_S
Andy_S's Avatar
The old smaller bore (1.75") system should have had the peak torque lower down the revs, so I guess I've moved that to higher revs now.
Hopefully that gets me a better top end, but to be honest I just like the look of the big bore tubes
I made it from components I bought from these guys :
http://cgi.ebay.co.uk/T304-Stainless...QQcmdZViewItem
The single pipe rear box is made by my own fair hands from some of the tube which I slash cut & welded into a 6" X 450mm round silencer.
I know what you mean about needing headache tablets, the twin pipes act as amplifiers not silencers
Old 31-03-2008, 07:53 PM   #6
Smurfy
Smurfy's Avatar
I got my exhaust parts from the same place, I thought the front box looked familiar.
Old 31-03-2008, 08:00 PM   #7
Allan McD
Allan McD's Avatar
CC: 2350 t
Looking good but I dont think itl pass the noise test
Allan
Old 31-03-2008, 08:04 PM   #8
garyshoose
garyshoose's Avatar
CC: Sold
ECU: Honda
Hmmmm, so i take it the front box makes it a lot more respectable then I was considering that but wasn't sure if it was a waste of money or not. Like the spotty peg bucket BTW
Old 31-03-2008, 08:15 PM   #9
Smurfy
Smurfy's Avatar
Mine was alot quieter with the front box. My dad borrowed a meter from a mate and mine read 86ish dB at 3500RPM, the highest I could get it was just over 90dB. Unfortunately I don't have any readings before I added the silencer.
Old 31-03-2008, 08:21 PM   #10
Andy_S
Andy_S's Avatar
I don't think the front silencer makes a huge difference (although Smurfy's comments suggest it is), I reckon it's the rear one that's doing most of the silencing ......... bigger is better and all that.
He deffinately wouldn't pass the noise test with the twin pipes, but with the single I'm reasonably confident. The two boxes are very different in construction, the twin is a totally hollow, whereas the single is a perforated through pipe with silencing 'wadding' around it.
Old 31-03-2008, 09:18 PM   #11
PaulW
PaulW's Avatar
ECU: Megasquirt MX5 Pnp
Looking good Andy you look like your almost there.
Paul
Old 01-04-2008, 02:53 PM   #12
markrally73
The noise limit for sprinting was 110db in the 2007 blue book, has it changed this year?? I havnt got my liscence through yet.
Mark
markrally73 is offline   Reply With Quote
Old 01-04-2008, 03:12 PM   #13
Andy_S
Andy_S's Avatar
It depends which approach to sound testing that the scrutineer takes.
There are two methods of testing (so says the blue book);
i) At a 0.5m radius from the exhaust with the noise meter between 0.5 & 1m off the ground then max for Libra cars is 98db.
ii) Where the exhaust is not accessible, the test can be done at a 2m radius from the centre of the vehicle 1.2m off the ground and a max of 110db for for Libra cars.
There are quite a few bike engined Westfields at the Sprints and they run some really beefy looking silencers to keep the noise down, so maybe you will need to run with quite a substantial can too.
Just to be on the safe side order an analogue noise meter (got mine for 23 off e-bay) so you can do some 'testing'
Old 01-04-2008, 08:03 PM   #14
Miniwidow
Miniwidow's Avatar
CC: 1597
ECU: points, remember them?
Originally Posted by Andy_S
Just to be on the safe side order an analogue noise meter (got mine for 23 off e-bay) so you can do some 'testing' & I'll look in my 'blue-book' tonight & confirm the allowable noise levels.
Did you really??? 'Hands on hips, foot tapping'
Just call me 'Daisy' ;)
Allow Smilies No Can Upload Images for Signature No Can Upload Animated GIF for Signature No BAH HUMBUG!
Miniwidow is offline   Reply With Quote
Old 01-04-2008, 08:55 PM   #15
BassAddict
CC: 1798
He registered your complaint at 92dB with it
