Old 10-01-2018, 04:34 PM   #1
Default digital Dash - 1800 quid budget
What would be the best digital dash i can get for 1800 GBP ?
GPS ? data logging ? TFT screen ? etc
what people used / seen ?
Old 10-01-2018, 06:36 PM   #2
I think Dan's got some Auto meter ones in his car but can't find any photos of them after the photo bucket debacle last year.
Old 10-01-2018, 07:23 PM   #3
Got SpeedHut gauges from the states, you can design your own, plenty of choice and they’re very good quality.
https://www.speedhut.com/?_vsrefdom=...SAAEgL8ZfD_BwE
Old 10-01-2018, 07:26 PM   #4
Old 11-01-2018, 04:24 AM   #5
PaulW
PaulW's Avatar
ECU: Megasquirt MX5 Pnp
I think Matt is after something like this?
http://www.etbinstruments.com/
This is the one i will be going for in Stella eventually
Old 11-01-2018, 08:26 AM   #6
I think a few people use an app and a tablet/smartphone
Old 11-01-2018, 09:49 AM   #7
You could use a tablet but the boot up would be very annoying and there are digital dash rules like on power up the speed should be shown by default.
I've got an Acewell dash that I bought used for £100, should be within budget
Old 11-01-2018, 09:54 AM   #8
Has all the other dash lights built in too
Old 11-01-2018, 02:33 PM   #9
Haz
I have the acewell dash too, same as above. It's OK but the magnet speed sensor is forever letting go sending a magnet flying around the bay... Previous owner hasn't set up the tachometer correctly either, reads 9k rpm before vtec not a slight on the kit by any means. I'd just suggest that the speedometer could be better, maybe consider running a standalone analogue one?
Old 11-01-2018, 04:19 PM   #10
Ha yeah I've 2 pack glued the magnet to the driveshaft, it does work fine but could come off I suppose.
Acewell do offer different speedo pickup attachments so you could adapt it to a pg1 cable drive.
My rev counter is right
Old 11-01-2018, 04:58 PM   #11
I did this on mine with Araldite but what I found when I pulled the engine out of my car was that the magnet had (albeit over a period of 10 years) rusted away to almost nothing
Old 11-01-2018, 05:18 PM   #12
arterz
arterz's Avatar
ECU: OBD0
I use acewell 3252 for a few years now with very good results, I'm very happy with it.
For speed sensor signal I used the original VSS from honda. It has very accurate readings from this sensor. Also I have custom made fuel tank and use an old fuel sender from HiAce Toyota Van iirc, 0-130 ohm resistance,, acewell uses 0-100, I simply adjusted the fuel sender from the pivot arm and have very good results too.
mitsos mini 16v
Old 11-01-2018, 05:30 PM   #13
Yeah they do have other speedo option available
At least magnets are easy to replace though and if it says on 10 years I'm happy
My model of Acewell has a programable range for the fuel sender so can be used with pretty much anything
Old 11-01-2018, 06:07 PM   #14
arterz
arterz's Avatar
ECU: OBD0
My second acewell setup had a small failure, my friend's Golf mk2 has acewell dash too, and we use the acewell reed speed sensor with the magnet but it fails at 65 to 95 kmh, when it comes at those kilometeres the readings goes crazy and after 95 km become normaly again, it's very annoying, I don't know what else to do, I tried many diferent ways to mount the sensor!
sorry if I'm off topic
mitsos mini 16v
Old 11-01-2018, 07:54 PM   #15
Muffyvaux
Muffyvaux's Avatar
Dash 2 pro or the new aim tft screen dashs. Both can be can bus controlled by your ecu. Also linked to GPS data logging etc
