Old 05-09-2018, 07:15 PM   #1
cooper_mark
cooper_mark's Avatar
Default how have you run fuel lines
doin a honda build using watsons frame
how have u guys routed your fuel lines as there's not enough room where they normally go up inbetween the subrame and bulkhead on the passanger side
my beast
Old 06-09-2018, 01:21 AM   #2
I have just got a set of MPi Mini fuel lines and fuel tank with pump and used them.
Old 06-09-2018, 07:34 AM   #3
My fuel lines (SPi Cooper) ran in the normal place with my old Watsons frame from what I remember. With my Custom Minis frame they run in the same place except I had to slightly bend them as they caught against the lower floor mount.
Old 06-09-2018, 07:48 AM   #4
I've ran -8 braided lines through the car and up through the passenger side brake blanking plate with a mpi tank in the boot.
Old 06-09-2018, 08:43 AM   #5
-8 teflon braided through the car, -6 return, fuel cell in boot external pump
Old 06-09-2018, 08:57 AM   #6
cooper_mark
.yeh got fuel lines and mpi tank...just dont want lines thro the car
gonna dive in the garage now and see where if theirs a way between the subframe and the bulkhead
my beast
Old 06-09-2018, 12:49 PM   #7
Oh, I see what you mean now Mark. I actually ran the metal pipes to the bulkhead then have rubber hoses running through the round holes near the rack into the engine bay. It's a bit awkward and realise if the subframe needed to be removed, I would have to remove these pipes too.
Old 06-09-2018, 01:19 PM   #8
cooper_mark
couldn't see any other way of routing the pipes how i wanted them
thats exactly how ive done mine this morning...just got to order some flexi/rubber hose
my beast
