Old 08-11-2017, 09:13 PM   #1
Deedub72
Default Mpi ignition
Hi guys I'm wanting to wire my mpi ignition into the Honda loom I know what wires do what on the Honda but need help with the mini wires as I can't find anything anywhere.ideally wanting to know what colours do what ?
It's the yellow, white, brown, white and red tracer and the green with white tracer
cheers and thanks
Deedub72 is offline   Reply With Quote
Old 09-11-2017, 07:51 PM   #2
roybills5
CC: B16
ECU: P30
Yellow is power supply to rear heated screen and sunroof
Browns are power in from main maxi fuse box
White is ignition feed to fuse box
Green turns the aux relay on
White and red sends 12volt to the MEMS control unit to turn starter relay on
You could use this wire to control your own starter relay or you could use the
red and brown wire that comes out of the MEMS control unit to power your starter solenoid
Hope this helps
roybills5 is offline   Reply With Quote
Old 09-11-2017, 08:27 PM   #3
Deedub72
The colours I have for the Honda are
White -12v perm
Black/White - starter
White/black - accessory
Black/yellow - ignition 1
Yellow - ignition 2
So I'm thinking it's
Mini brown to Honda white
Mini white to Honda yellow
Mini white/red to Honda black/White
Mini green to Honda white/black
Mini yellow to Honda black/yellow
Old 09-11-2017, 10:41 PM   #4
roybills5
CC: B16
ECU: P30
White -12v perm
Yellow - ignition 2
Mini white to Honda black/yellow
Mini yellow to Honda yellow
Slight change to ignition wires I think
Old 10-11-2017, 08:03 AM   #5
Deedub72
Brilliant ill give it a try thanks for that
Old 10-11-2017, 07:27 PM   #6
Deedub72
Ooops dropped it and smashed all the black switch casing haha
