Old 03-07-2017, 09:28 AM   #16
Do you have any local mobile welders in your area ?
Old 03-07-2017, 04:22 PM   #17
1994alex
ECU: Omex
Not that I know I have called some companies but they will not touch cars, I'll try and get in contact with rightline motorsport or allumy motorsport or endaf Owens, although so have tried multiple times to contact endaf and cannnot get through
1994alex is offline   Reply With Quote
Old 03-07-2017, 07:14 PM   #18
AWD
Alex, get me a ticket and i Will deal with your cage!!
Old 03-07-2017, 07:26 PM   #19
1994alex
ECU: Omex
That's so tempering! Your work is fantastic!
Old 12-09-2017, 12:40 PM   #20
1994alex
ECU: Omex
Right so little bit of an update it really isn't much as progress has been slow! I now have an all speed frame one of the new style ones and one of custom cages Kigali a cage! So hopefully in the next month or so the shell will be all welded up and ready to go to the body shop for painting!
Old 20-11-2017, 07:44 PM   #21
1994alex
ECU: Omex
Right so another update haven’t had one in a while! So I have sold the roll cage and ordered the red frame from AWD! So it’s feeling like 1 step forward two steps back! I have spoken to kad whilst planning the build and they have said that they will look into doing a set of rear brakes for me and a front roll bar!
I’m also selling the carbon floor and Kevlar boot lid now, I feel that the Kevlar will not go with the Audi bardo grey! So I’m thinking of getting one made which is carbon exposed weave outside and the frame on the inside in Kevlar to run with that theme! I have also spoke to The Arc Angels and will hopefully be getting a custom front with a bit of a twist!
Can anyone help with the pictures to why they are no longer working?
Alex
Old 21-11-2017, 02:06 PM   #22
AWD
https://nl.imgbb.com/
Old 21-11-2017, 04:29 PM   #23
One word - Photobucket
http://www.16vminiclub.com/showthrea...t=37414&page=2
http://www.thisisinsider.com/photobu...rs-p500-2017-8
Old 12-12-2017, 10:44 AM   #24
1994alex
ECU: Omex
Right i have managed to get the pictures back but just in thumbnail view some pics are better then none!
Right so the boot floor, boot lid an cage have been sold so that has funded an AWD rear subframe! thats right I'm definitely going 4wd turbo vtec!
Old 12-12-2017, 11:52 AM   #25
AWD
Will help you out with some pics of your AWD frame (in progress) to keep your build tread complete.
Old 12-12-2017, 03:19 PM   #26
1994alex
ECU: Omex
Thats brilliant AWD thank you! as you can see its slightly different to AWDs other frames
Old 14-12-2017, 03:29 PM   #27
1994alex
ECU: Omex
Right so made a few phone calls this morning to try and get some quotes with regards to the engine build, manifold, turbo, exhaust, intercoolers and radiator fabrication, it was a bit more the expected but both are off high end fabricators and engine builders!
So the plan now is to build up both frames front and rear then send it off to endaf owens for the roll cage fabrication i don't know if this is a smart idea in the way i am doing it or would it be best to get the engine built then send it to endaf for the fabrication of the shell and then finally the manifolds what would you guys suggest?
Old 30-12-2017, 11:54 AM   #28
1994alex
ECU: Omex
So the rear arrived from AWD just before Christmas so it was like christmas had come early, i don't think i have ever been so excited over something being delivered!
The frame
After i finished work one day i thought i would quickly run up to the local scrap yard to see if they had anything that may help and by chance they have two honda Crv's with everything i need so I've bought both drive trains and engines!
The one has even been declared as scrap yet!
I managed to get the diff off of the one yesterday as i only had an hour spare so i thought i would get what i could!
With the diff just sitting in so i could get an idea of what i need for the rest of the frame!
I am trying to work out if i could get a custom set of rear flanges made that will fit the mazda hubs so i can still use mini parts! i don't mind mixing and matchin but i feel that it just may look nicer and be more helpful in the future, does anyone know if KAD or force racing may be able to help?
Alex
Old 30-12-2017, 01:08 PM   #29
GEORDIE SP1
GEORDIE SP1's Avatar
Iím going to machine front mini hubs to 4-100 PDC, better off with the 12 mm studs etc.
Old 30-12-2017, 08:16 PM   #30
1994alex
ECU: Omex
Well another idea I had was to remove the studs off of the Mazda flange and weld them to the mini pcd? Is that possible or is that a stupid idea?
