Old 21-03-2017, 08:54 AM   #31
AWD
Originally Posted by GEORDIE SP1 View Post
Hi, Have you made your rear driveshafts yet, wondering what length your getting, mine are working out about 465mm, Cheers.
I made them already! there is 30mm difference in left and right because the diff output is not in the centre of the diff housing. so, you put the diff output in the centre line of the car so your prop shaft is in the centre so 1 driveshaft is shorter then the other, about 30/35 mm.
Old 28-03-2017, 02:17 PM   #32
Brumski
ECU: Mini Tec uprated Honda
Nice. Was the rear diff easy enough to do? What seals did you replace or was it a full stripdown?
Old 28-03-2017, 02:23 PM   #33
AWD
Not a full strip, wasnt needed.. no play in the diff so replaced only the driveshaft seals and the propshaft seal out of precaution. it sucks to have to do that when everything is nice and tight under the car
Old 28-03-2017, 02:26 PM   #34
Brumski
Agreed. It's a job I'll do for sure before the final fitment of the diff.
Old 28-03-2017, 02:30 PM   #35
AWD
its a 30 min job and about 35 euro's.. no reason not to do it anyways
Old 01-04-2017, 10:05 PM   #36
Bennjaminozhonda
Great setup
Did you consider any other rear diff - considering the crv job is a hydraulic clutch pack thing which is stupidly complicated - or did you strip the internals etc?
Bennjaminozhonda is offline   Reply With Quote
Old 02-04-2017, 04:07 PM   #37
DVO
DVO's Avatar
ECU: Chipped
Sent you a private message
Dennis
Old 03-04-2017, 03:45 PM   #38
AWD
Originally Posted by Bennjaminozhonda View Post
Great setup
i am using the crv-1 diff, its mechanical. the later models have a hydraulic system and you dont want to use that
Old 04-04-2017, 08:00 AM   #39
Originally Posted by AWD View Post
Have you tried your fuel rail on there yet ? It may just be the angle of the picture but the inlet looks tight enough to the head to foul the fuel rail
Old 04-04-2017, 10:08 AM   #40
AWD
Its the picture.. all fits just fine! i have build this mini already 2 times to make sure everything fits the way i want to.
Old 04-04-2017, 10:33 AM   #41
Cool
Old 01-05-2017, 11:33 AM   #42
AWD
Not much to do at this moment.. just a few little thing here and there.. waiting for the body to come back from paint! All other things are done, prepared and ready to build the mini for the 3rd and last time
Old 17-05-2017, 10:02 AM   #43
AWD
just little bits and pieces.. the tank is almost done! Received a few boxes from the UK.. nice! everything is here to finish the mini when i gets back from the painter.. takes forever btw..
Old 29-05-2017, 09:07 AM   #44
AWD
Tank is done!
Made the front shafts now in a different way. Made new (mini) splines on the honda shafts.. not easy but it works very well! So, no more joints!
Old 13-06-2017, 05:59 AM   #45
AWD
primer, slow going.. still needs a lot of work... another 3 weeks and i hope its all done
