Old 09-08-2017, 01:40 AM   #31
Thumbs up
o well nearly lost thumb and get straght back to it
Old 09-08-2017, 09:12 PM   #32
joltfreak
joltfreak's Avatar
ECU: Standard-ish
That's the Plan!!!
The shell should be finished and painted by the end of this week.
And I'm itching to get back at putting it together again.
Old 13-08-2017, 12:25 AM   #33
joltfreak
joltfreak's Avatar
ECU: Standard-ish
The van is finally out of the paint shop!!
There is one or two spots im going to fix up but i i really like it!!!!!!
Old 13-08-2017, 01:52 AM   #34
nice!! so tell us? is that a genuin canadian mk1/2 door?
Old 13-08-2017, 03:05 AM   #35
joltfreak
joltfreak's Avatar
ECU: Standard-ish
No, they are the original aussie doors that were on the van.
Old 13-08-2017, 01:28 PM   #36
coor they got the good bits, i herd but not seen one,
thought it may have been canidas take on safety like the other door safety bars and ugly massive fenders, wher the hell do you keep your beers, lol
Old 13-08-2017, 06:06 PM   #37
monkey
monkey's Avatar
ECU: A box of chips
Funky to see the inside of the door like that!
Old 15-08-2017, 10:17 AM   #38
Jaapio1984
Jaapio1984's Avatar
CC: 1800CC
ECU: MEMS
Send a message via MSN to Jaapio1984
Some people may ask why would i want to sell these two mini to build another?
The main reason is that both these minis are two seaters and i have two kids that always want to go for a ride whenever i try to take one of the minis out....
That being said, I never get to drive these minis.
My plan with this mini build is to be able to seat 4 people and still have LOTS of fun!!
and your building a VAN.. or are you going to fit one of the rearseat conversions for the VAN..
"If everything is under control, you are just not driving fast enough"
by:Sir Stirling Moss
Jaapio1984 is offline   Reply With Quote
Old 16-08-2017, 02:21 AM   #39
joltfreak
joltfreak's Avatar
ECU: Standard-ish
Yup! I'm building a van. I'm planning on putting back seats (rumble style) in the back
Old 21-08-2017, 11:46 PM   #40
joltfreak
joltfreak's Avatar
ECU: Standard-ish
It's a tight fit but it all went in quite well!
Once I make it a roller, it will need to go back to the paint shop for a couple small things I wanted cleaned up then back to putting it back together!
Old 30-09-2017, 07:20 PM   #41
joltfreak
joltfreak's Avatar
ECU: Standard-ish
Not too much to update....
Ran all the brake and fuel lines. I also test fit my grille to see if it fits well.
I have to trim the backside I'd the grille a bit to clear the headers.
I picked a alloy tube to make the air intake and got the air filter to fit.
I fit the gas tank and was also able to get the car down to my buddy exhaust shop to get the stainless exhaust put in.
Old 30-09-2017, 07:28 PM   #42
joltfreak
joltfreak's Avatar
ECU: Standard-ish
Got the brake and clutch pedals in, connect the brake and clutch lines and started to fill them so that I could bled them and the are leaking.......
They leak where the lines go into the masters....so I decided to focus on the wiring for a bit so I could calm down and think this through.
Old 06-01-2018, 11:38 PM   #43
joltfreak
joltfreak's Avatar
ECU: Standard-ish
It's been a while since I've given an update,
Most of the wiring is done. I have pressurized the fuel line and no leaks!
I have turned over the motor but I don't seem to have any spark.....
I'm not sure if the issue I from the CPU or the ignition system.
I also decided to bite the bullet and I got another CPU with the hondata hardware.
I still need to find out why I don't seem to have any spark. I just need this cold snap we are having to end!
Old 07-01-2018, 01:31 PM   #44
mikko
mikko's Avatar
ECU: obd0
where'd you get the grille? never seen one before
Old 07-01-2018, 05:07 PM   #45
Looks like an early Innocenti one
