Old 17-03-2017, 11:33 PM   #16
bluemini17
CC: B18
ECU: P9k
forgot to mention, I received a call from Allspeed on Thursday, frame is posted and I can expect delivery this week coming
bluemini17 is offline   Reply With Quote
Old 18-03-2017, 09:05 AM   #17
robert_paull
Excellent work
robert_paull is offline   Reply With Quote
Old 18-03-2017, 09:20 AM   #18
Underhauled
If you're getting an allspeed rig why are you cutting the front and extending it?
Old 18-03-2017, 09:39 AM   #19
bluemini17
CC: B18
ECU: P9k
It can be done without extending but it is very tight and requires custom rad, exhaust manifold, fiddling with the steering rack and also the clutch slave. Not to mention cutting more out of the bulkhead and also the front panel to accommodate the alternator.
With the extended front I will have the look of a round nose but with the convenience and space of a clubman. Or here's hoping.
Old 18-03-2017, 09:40 AM   #20
Underhauled
Furry muff. Watching intently.
Sent from my SGP311 using Tapatalk
Old 18-03-2017, 10:16 AM   #21
mikko
mikko's Avatar
ECU: obd0
Nice work addressing the pedal differences, but you seemed to have stopped just short of spec'ing an appropriate master or slave, I dont think it can ever be as smooth as the honda, which is 28mm actuation for 4-5ish inches of foot travel, foot travel in a mini is 3-4", condensing the 28mm into 1-2" of foot travel using honda components leads to an on/off clutch.
Old 18-03-2017, 10:19 AM   #22
robert_paull
I just love a good build
Old 18-03-2017, 04:04 PM   #23
bluemini17
CC: B18
ECU: P9k
Mikko, fantastic input, greatly appreciated. As I'm up against the wall with time I'm going to crack on with the Honda Master and then start looking into alternatives after the imm car show. These builds are great for testing the grey matter
Old 18-03-2017, 04:05 PM   #24
bluemini17
CC: B18
ECU: P9k
I cut the front off the poor fella today, link to YouTube video...
https://youtu.be/uRod4vm4XgU
No going back now!!
Thanks, David
Old 18-03-2017, 05:14 PM   #25
Underhauled
Ah memories. Some feeling when the first sparks fly.
Sent from my GT-I9505 using Tapatalk
Old 11-04-2017, 09:56 PM   #26
bluemini17
CC: B18
ECU: P9k
quick update, its been two weekends after all
Front end cut off, bulkhead cut / welded and made good. Nice clearance all round. Needs seam sealed etc, im doing a dry build so will address when the time comes for paint.....next week
Moved onto fitting the engine into the frame and then onto the car. I then decided on a front end stretch of 50mm, this gives me some play with the engine but hopefully retains the mini shape.
Usual carry on, cut, weld, linish back. Will work the panel lines some more once i get ready for paint.
I then moved onto the gear linkage, it was handy enough done. I made the solid link bar first then the actual selector bar. All gears work and the gear stick is in a similar position to the mini one, if not better.
Once that task was ticked off i could then make the exhaust. For the time being I am using my existing RC40 1.75inch bore exhaust. I measured my honda one and it is 2inch in places and between 1.75 and 2 in others. Will see how it sounds and feels over time. I incorporated a flexi joint just after the exhaust manifold.
I also rotated the oxygen sensor by 90 degrees.
Time has been limited this past two weeks, I have only had Monday night, Wednesday night and Friday night, maybe 3hrs at a time. I'm impressed with how my progress is going. IMM 2017 is looking possible.
Thanks, Dave
Old 12-04-2017, 07:33 AM   #27
good progress
Old 12-04-2017, 06:46 PM   #28
Mini Vlatko
Mini Vlatko's Avatar
Loving the progress and how fast is your build is going but why are you extending your front with Allspeed frame?
Not a fan of extended fronts
Old 13-04-2017, 10:10 PM   #29
bluemini17
CC: B18
ECU: P9k
Gives me an option for a turbo, I plan ahead
Old 14-04-2017, 05:39 AM   #30
Mini Vlatko
Well that's a valid argument
By the way...where can I find these "clips" and what are they called?
