Old 14-07-2016, 08:14 PM   #1
Simples
Default D Series Roundnose
Here's a summary of where I am so far
Test polished a wheel
Brought some panels
Made access on the car a little easier
One oversill
What remained underneath
Most of it cut out, rust treated and started cleaning it up
Took an angle grinder to my brand new rear valance
Filled in the screw holes for the arches
Also had a look behind the flitch repair
Welded in the fuel filler blanking plate
Cut some more holes
Also started on the boot floor
Got some colour on, subtle enough
Simples is offline   Reply With Quote
Old 15-07-2016, 02:26 AM   #2
30 mm
30 mm's Avatar
ECU: square case
Looking good!
30mm
Old 03-08-2016, 10:06 PM   #3
Simples
Thanks!
Shell's the right way up (first time in a year or so)
Started on the rear panel repair and found a lot of filler
I was waiting to find a load of crumpled metal, but it was just to cover the previous substandard repair
The boot corners
How it's left for now
Old 04-08-2016, 04:36 PM   #4
fordy
fordy's Avatar
ECU: Standard P9k
Keep up the good work pal. Was in the same boat myself a few months back. Keeping motivated was the hardest thing I found especially when you keep finding rust!
I found YouTube helped a lot!! And of course this forum. Looking at others builds really helped me. 👍
fordy is offline   Reply With Quote
Old 04-08-2016, 09:02 PM   #5
Simples
Cheers pal, yeah it's ok at the minute whilst I've got the love for it again
Old 20-09-2016, 06:22 PM   #6
metalwright
ECU: MS3-Pro
Looks quite a lot like my rear panel!
metalwright is offline   Reply With Quote
Old 02-10-2017, 06:39 PM   #7
Simples
This is well overdue an update...keep getting distracted by other things O_O
Been collecting parts, even if they're not needed for a while
Brought some trunnions and started to converted the rear subframe to a beam set up
Seam welded the rear tubs and will strengthen the top mounts too
Started on the rotten boot floor to rear panel
Saw a few bits round the rear subframe mounts so it ended up like this
Also welded some reinforcement into the heelboard for the rear beam to bolt to. Hopefully be a bit more consistent with progress from now on*
Old 08-10-2017, 02:52 PM   #8
Red Riley
Red Riley's Avatar
Depending on what shocks you end up using, you might need to tub out the shock towers. I'm using these coilovers that have an offset on the upper and lower mounts to clear the arms, but they need some room to swing or they will bind up on the shock tower walls. I'm using this setup on the Half-Elf trailer I'm building.
Red Riley is offline   Reply With Quote
Old 08-10-2017, 09:02 PM   #9
Simples
Good to know. Thanks
