Old 16-05-2017, 08:39 PM   #76
fordy
fordy's Avatar
ECU: Standard P9k
So eventually found the root of my problems.
After a lot of investigating, but luckily didn't actually get to the point of buying different parts, ive managed to sort it.
Since my last post I had another light come on which was the crank sensor. Ended up stripping the dizzy to check sensors and wiring inside, traced all my existing wiring to double check it all. Whilst doing this, after resetting the ecu (removing battery earth) started the car up and no codes appeared. Then brushed past the jumper harness from ecu and the car bogged down and nearly cut out. So moved the wires again and same thing happened. Then it threw the code again!
Ended up being the connections in my jumper harness. The male pins were that slack in the females that even the slightest movement broke the connection.
Ended up stripping a handful out, metering them, crimping up the females to make them tighter on the pins and bobs ya uncle.
Sorted the rad clearances, changed the inner cv joint gaiter too.
Took it out tonight, no codes, revs perfectly and even hits vtec.
It's mentally quick too!!! Far exceeded my expectations. Just need to get the geo properly set up now and put some miles on him.
fordy is offline   Reply With Quote
Old 17-05-2017, 05:56 PM   #77
Excellent news - well done
Old 27-05-2017, 05:35 PM   #78
monkey
monkey's Avatar
ECU: A box of chips
We need videos!
Old 23-06-2017, 10:32 PM   #79
fordy
fordy's Avatar
ECU: Standard P9k
Few more pics for ya, will try and get a decent video uploaded soon.
Still not had the suspension set up yet. Had a few more issues to deal with such as the oil pump failing on me. So that was changed out for a genuine item.
I'll be attending the ukminis rolling road day this weekend so hopefully get to See what he's kicking out.
If anyone's going come say hi.
Old 22-09-2017, 04:42 AM   #80
Just seen the minimag article - looks great. Spotted you have fitted jack points to the sills, have you got any details of what/how? Cheers
Old 22-09-2017, 11:19 AM   #81
fordy
fordy's Avatar
ECU: Standard P9k
Thanks yellow. Yeah proper chuffed with the feature and even more stoked to get on the cover.
Jacking points were simple really. As I've fitted spreader plates to the floor for my cage to sit on and bolt to, jut welded some 20x10 box section to the underside of these. No chance of going through now!!
