Old 14-07-2016, 10:53 AM   #1
fordy
fordy's Avatar
ECU: Standard P9k
Default 1973 b18 clubman weekender
Right, finally taking the time to sit down and start my build thread.
I've been working on my project now for around 10 months. The idea was to build a stripped out weekend weapon which could cope with the odd track day. Wasn't to bothered about having an immaculate car as long as it did the job, I did like the idea of the sleeper look. Oh how things have changed!!
It's now turned into a nut and bolt resto which is currently out for its shiny new paint.
From owning an ep3 type r for a long while the choice of engine was simple. I managed to drop on a b18c4 near full kit from a member who abandoned their project so close to the end. They were unable to get the thing to spark, so I took on the task.
Current spec so far.
B18c4 engine.
New exedy clutch
New genuine timing belt
Skunk2 inlet.
AEM fuel rail.
AEM fpr.
Kjb front subframe.
10" Minisport 4 pots.
Rebuilt front and rear suspension all Fully adjustable.
KAD rear camber brackets.
Gaz adjustable lowered shocks.
DSN alloy rear subframe mounts and front shock mounts.
6 point roll cage.
Removable steel front end.
10x6 weller wheels with AR032 tyres.
Omp silverstone classic bucket seats.
After many panels later and hours of welding, finally got the shell ready for paint. This included new passenger inner wing, a post, a panel,door step, inner and outer sill, both rear subframe heel board mounting points, boot floor, corners and hinge panel, rear valance, door skins.
Well, save boring you all with the rest of the details I'll let the pictures say the rest.
Please let me know what you think.
Removed all unneeded wires from the loom.
Removed and labelled engine loom
So after hours and hours of tracing wires, removing un wanted bits and checking and double checking connections finally found the problem. A wire was in the wrong terminal on the ecu plug. Changed it over and .............
So with that done I now began the search for a car. Which didn't take long. I needed some room in the garage so decided to get rid of some seats I had lying around. So put them up for sale. A chap turns up, got to talking and turned out he had the exact car I was looking for. Tax exempt, 1973 clubman in black.
Clearly needed some work but emotions got the better of me and we did the deal. Turned out to be shifty off of this forum.
They turned out to be an expensive pair of seats for me!!!!!!
So the build really began....
New inner wing, A post, A panel, door step.
Passenger floor pan.
Inner and outer sills going on along with heel board subframe mounting points.
Moved on to the boot floor. Including both rear corners, hinge panel and valance.
Red oxide, Seam sealant ready for the stone chip.
Then ran brake and fuel lines.
Thought it was easier to get the subframe on while it was on its side. Going on with the DSN classics alloy subframe mounts.
[URL=http://s177.photobucket.com/user/fordy_09/media/Mobile%20Uploads/image_37.jpeg.html][/
fordy is offline   Reply With Quote
Old 14-07-2016, 10:55 AM   #2
fordy
fordy's Avatar
ECU: Standard P9k
Refurbish the suspension parts. New shafts, bearings,ball joints. And a lick of paint.
Radius arm in. Fitted with KAD adjustable brackets.
I decided that to aid getting the engine in and out id make the front removable. Also wanted to keep it steel. So this happened.
Made up some Brackets for under wings.
And welded a piece of box to the front panel that connects to the front cross member on the frame.
I found that when the exhaust manifold was on, clearance on the front cross member was an issue. So made some spacers to pack that out. I then had to mod the front panel so the frame was not protruding through. This meant cutting and adding some small fillet pieces in to allow clearance. I'll then move the number plate down over this so won't be too obvious what's going on underneath.
Engine in, with front end all bolted on to check clearances. Good all round apart from the rack. Solved this by making a new rear mount bracket that enabled to engine to tilt enough to clear the rack and also take some of the strain off the mounts.
New mount bracket.
Quick mock up of front suspension and brakes.
As the lip on the scuttle was rusted out and a repair already put in I decided to change the full scuttle panel for a genuine one. Also gave me good access for doing the bulkhead box. Which is needed to clear my inlet.
Box in place and bulk head stripped, Seam sealed and primed.
Also note the small square cut outs under the cross member. These are for the wiring harness to come through so keeps the engine bay clean from too many wires.
Plates I made for the harness to go through. These will be cut into 2 halves, which clamp over the loom along with a grommet and gasket.
New scuttle on. And also had a go at a little something different for the engine bay. Bit a homage to Honda. I've used a wrinkle finish paint that Honda's historically use on their rocker covers. Was a right bitch to get right but worth it I think.
Had to make some fillet pieces to finish off the corners. These will also be extra fixing points for the front end.
Alternator bracket.
Test fitting the arches.
And off to paint he went.
So with the car gone, turned my attention to the engine. Cam belt, clutch and a tidy.
Built up inlet manifold. Aem high flow fuel rail and pressure reg.
And as it stands now.
Finished the clutch tonight and finished painting little bits and bobs.
Need to get the front frame off the car and away to the powder coaters now along with the rollcage. Hopefully have the car back next week. Fingers crossed.
Old 18-07-2016, 07:09 PM   #3
fordy
fordy's Avatar
ECU: Standard P9k
Bit more done today.
Mainly wire brushing, cleaning and painting parts. Also fitted some of the parts I've done previously to the engine.
Need to decide on a colour for the cam cover still though. ???
Alternator bracket welded up and painted.
Then threw the inlet on just to give me an idea what the overall look will be. Quite happy with it so far.
Old 18-07-2016, 09:31 PM   #4
Underhauled
That engine looks great. Elbow grease or did you blast it clean?
Old 18-07-2016, 10:11 PM   #5
fordy
fordy's Avatar
ECU: Standard P9k
Thanks man.
Luckily the last chap did most of the elbow grease. It was pretty clean when I got it. Just brushed some degreaser over her, and painted her up. I used some por15 hight temp manifold grey paint which went on really well.
Old 21-07-2016, 08:47 PM   #6
fordy
fordy's Avatar
ECU: Standard P9k
Trying to keep busy and on top of things while the cars still away. Might be getting a bit carried away though.
Stripped and painted the pedal box.
Also started on an old badge I found amongst my boxes of tat. I will eventually tie it into what ever colour I have my wheels.
Old 31-07-2016, 06:47 PM   #7
fordy
fordy's Avatar
ECU: Standard P9k
Had an eagerly awaited message from my painter yesterday to let me know how he's doing.
So here's a sneak preview of colour.
Really stoked with it, can't wait to see it in person and in the sun.
Colour is ipanema brown.
Old 01-08-2016, 10:00 PM   #8
leon
leon's Avatar
Dang! that looks ace man. Love the colour
I live like my blood type is B positive
Old 01-08-2016, 10:07 PM   #9
fordy
fordy's Avatar
ECU: Standard P9k
Thanks Leon.
Was real nervous about it, didn't know if it was going to suite the car. But with the chrome bits and what not I think it's going to look sweet. Especially in the sun.
Hopefully pick it up Thursday if I can get a trailer sorted, so Will update with a few more pics.
Old 01-08-2016, 11:38 PM   #10
I would have been nurvuce too, but your gamble payed off..
looks mint for a gun finnish wiv no semi pro mopping,
Old 02-08-2016, 08:53 PM   #11
fordy
fordy's Avatar
ECU: Standard P9k
Went to have a look at the car today. Looks great. Fantastic in the sun. Pictures don't do it justice. But here's a few to give you an idea. He was still polishing it when I got there.
Old 05-08-2016, 08:04 PM   #12
fordy
fordy's Avatar
ECU: Standard P9k
So collected the car yesterday. Looks great.
Stuck the wheels on straight away to try and get an idea of colours so I could send them off to the powder coaters ASAP. I love the look of the wellers but somehow think now that they just don't compliment the car. What's people's thoughts?
I'm away this weekend, but Monday I'll be very busy.
Tried the wheels on.
Old 05-08-2016, 08:20 PM   #13
Off-white or cream, with brown pinstripe ...
Old 05-08-2016, 08:27 PM   #14
fordy
fordy's Avatar
ECU: Standard P9k
Was thinking about an old English white. Like the idea of the pinstripe. Thanks man.
Old 05-08-2016, 09:09 PM   #15
monkey
monkey's Avatar
ECU: A box of chips
If you don't want the wellers, I do
