Old 08-03-2017, 04:03 AM   #46
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
meanwhile i did a bit on the Mini:
After having a little pause and welcoming my son, born on November 7th, i finally found a bit time to do a bit on my project.
welded in the pump mount in the tank:
flattened it up to get no touch to the floor:
And played a bit with building an exhaust :
Also fittet the fuel lines as also the brake lines bend:
After rethinking my choice of material i went for using polyurethan lines:
Build: D16Z6-Van-Project
Austinvti is offline   Reply With Quote
Old 20-07-2017, 06:26 PM   #47
Mini91
Is there a chance to get the images again?
Mini91 is offline   Reply With Quote
Old 21-07-2017, 05:46 AM   #48
Mini Vlatko
Mini Vlatko's Avatar
Like this maybe?
Old 23-07-2017, 10:50 AM   #49
Mini91
How did you made that?
Old 24-07-2017, 05:26 AM   #50
Mini Vlatko
I just quoted the post and add this at the end of every link with pic: ~original
Should end up with this at the end: jpg~original[/IMG][/URL]
Old 31-07-2017, 01:52 PM   #51
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
thx for the advice.
Sadly this effect will pop out on every free user posted album.
400$/year just for sharing a handful pictures is def not what i want to pay for. :P
So concequently i will post coming pictures over another upload alternative
Old 10-11-2017, 12:53 PM   #52
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
just edited my last posts. So everyone can enjoy it, again
hopefully i add some news in the next time.
