Old 13-09-2016, 04:49 PM   #31
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Originally Posted by leon View Post
[...] Dont see a reason why the rad wouldn't cool, with a scoop and the amount of flow under the car it will be more efficient than a front mounted
You're right: the cooling effect is given also, if i install a scoop. But the negative touch comes with the spoiler effects. With every scoop that I attach below the vehicle , it brings the spoiler effect into this game.
The air which runs along the scoop will be pressed against the radiator...So long its ok.
After passing the radiators mesh the air is pressed against the floor. The lift force will increase, if there is no chance to vent the air with less resistance as possible.
That, i think will make the rear even lighter at high velocities.
The light rear of the Mini + Spoiler can bring it on the highway to fatal consequences.
So, I guess I should rethink the concept, maybe.
Build: D16Z6-Van-Project
Austinvti is offline   Reply With Quote
Old 13-09-2016, 04:51 PM   #32
leon
leon's Avatar
You are over thinking it. It will be fine
Sent from my D6503 using Tapatalk
I live like my blood type is B positive
Old 13-09-2016, 04:56 PM   #33
yes don't be a Fräulein
Old 13-09-2016, 05:03 PM   #34
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
thats what the university did to me
But you already know, that in germany on the "autobahn" v_max_legal>120mph
Old 13-09-2016, 06:49 PM   #35
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Found a solution: i think i install some Naca duct instead of a scoop. This will give me much less of circulated compressed air under the car
i know there is a lot of overengineered thinking here, but so what...thats me
Old 13-09-2016, 09:36 PM   #36
leon
leon's Avatar
too clever for this forum get outta here :P
Old 21-09-2016, 03:31 AM   #37
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Default Rear Frame vent and air supply
still not left the forum
i'd like to share my idea of how i want to install the rad in the rear frame.
Me, myself and Katja (aka CATIA) came to this:
The radiator is attached to the frame at an angle 5°:
How it looks inside of the frame:
rear view: vents and NACA in the cover:
And front view:
side view with spoile inside to force the air throug the rad:
Old 03-10-2016, 06:56 PM   #38
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Hi Folks,
something done in da "G".
Finally I found a bit more time to do some on the Mini.
So the cover of the rear frame is going to take shape:
And attached some vent holes to let the warm air out:
Also i finished the dash:
The second layer covers the ECU and all of the electrics to get a perfect finish.
Also i began with the exhaust:
Outer Exhaust brackets:
Distance - exhaust - floor: 6cm
Old 07-10-2016, 10:57 AM   #39
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Default Time to apply stone chip
After finished welding the last bolts for the petrol tank and preparing the last parts for the exhaust system, i finally applied the stone chip at the whole floor "mmmhhh shiny "
Also a last view on the exhaust chamber untill the exhaust will sit in
And the wheel housings:
Old 15-10-2016, 02:35 AM   #40
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Digital work on the rear frame finalized
So this is what i want to go for:
Frame perspective from above:
Side view (Air flow with spoiler) - without frame
with frame:
Old 15-10-2016, 12:35 PM   #41
I don't normaly like to put radiators in the back but your plans look realy cool,
wher is your petrol tank going to be?
Old 18-10-2016, 08:14 AM   #42
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
The tank is going to stay at its old place. But i am thinking about stretching it into the area where normally the exhaust pipe was.
the warm air of the radiator will hopefully go past the tank. Thats the reason for this "spoiler thing"
Old 18-10-2016, 11:12 AM   #43
cool, I did wander as don't look like thers space,
Old 29-10-2016, 04:24 PM   #44
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Don`t worry. There's always room for one more thing
Old 29-10-2016, 04:35 PM   #45
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
something to add: `87 Mayfair Sport went into my collection of Minis :P
next year it will get a historic license, hopefully:
But first i have to do a lot against the rust, including the original lights have to be mounted when finished. Also i had to remove several nonsense from the vehicle ^^. 12 inch speakers in the back seat OO. Floor light under the car.... Oh heaven help me ...
