Old 30-07-2016, 01:14 PM   #16
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
After having some sad news to my family, i thought of pushing this project to something later or stop it.
But doing stuff in my garage helps a lot.
So i did a bit:
ECU is in place and some mounting points added:
The cover still in card board:
Also decided to go for a complete new scuttle panel instead of repairing it:
Thought about some boxes for the hinges in this way:
But i was going this way:
Same to the other side. It is completly removeable and will be attached with some sealing after install of the doors.
The inner wings were also rusted so i replaced some metall:
The hole is for the loom going to the fuse box:
Build: D16Z6-Van-Project
Austinvti is offline   Reply With Quote
Old 30-07-2016, 01:27 PM   #17
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Default The rear axle
Next Chapter was to attach the rear stub of the honda to a metro xp radius arm. So it was nessesary to activate the mill:
This:
Must into this:
Some compared parts:
put together:
at work:
In place:
chapter "rear axle" will be continued later
Old 30-07-2016, 01:36 PM   #18
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Default Wheel housing
To have also a lot of space for up to 15" (195/45 R15) i had to increase the diameter of the housings
Hmm: What Wheel should it be?
15"
or:
14"
the other side also:
Old 30-07-2016, 01:42 PM   #19
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
First try with the 14": The wheel is turning correctly:
Old 07-08-2016, 03:18 PM   #20
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
After the wheel is spinning correctly, i had to adjust the track of the rear and welded it up instantly. In the rear i added a piece of cubed tube to give the cutted area a bit more strength.
Also i shortened the rear frame 5cm or 2.5cm each side, so it was necessary to add new mounting points. Comparing to the front frame i also go for a fixed frame
waiting for welding, the rear fixing point:
Old 07-08-2016, 03:43 PM   #21
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Default Adding the steering
I had to go for a complete new firewall in the area of the footwell. So it was also important to mount the steering
i decided to go for the mini quickrack (2.2 turns per side) so i used the old mounting panel of the old rusty footwell panel:
Steering in Place. Smaller steering-joint boots for the steering will avoid rubbing in this area. Hope so
To have no contact between steering rack and the frame i made a bit place for it and cut a small box to the frame.
As you can see the track of the MGF is much more wider than the minis original track. So there is usualy a gap between Steering and outer tie rod end:
Next step on the list is it to finally weld the frame up correctly with some knot panels and to stiff it up . If no other "next step" will interrupt me at this point . Muhahahhhaaa
Old 07-08-2016, 04:29 PM   #22
all good there,, love the vans and pick ups,
are you going to fill in the factory built in bedliner ruster holes?
them ones under the bed. the water traps
Old 07-08-2016, 07:21 PM   #23
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Hey. No i think i will let them open but fill it with a lot of grease or better rust preventing stuff available :P
Closing the holes might force the same like non venting sills. It will rust rust much faster. What you see in the pictures is only superficial rust.
Old 30-08-2016, 02:42 AM   #24
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Time for a small update
Finally i finished the complete floor.
cut out the shape of where the exhaust pipe will be:
made a piece of metall which will close it:
and bended it and welded in:
side view:
grinded:
just for testing (sort of pipe will change):
And also tried with some pipe how to create the exhaust.... how will it look with the 65mm pipe
Old 30-08-2016, 02:55 AM   #25
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Thats the floor for the moment and the actual last picture i have taken:
Right now, the seams were sealed and i made the final ​​preparations for the stone chip.
After this i will finish the "dash" and also the complete pedalbox including shift lever, hand brake cables, and so on .
Since I do not reach the ideal pedal travel caused by going upwards with the brake booster , I came with the following solution :
and in detail:
Old 05-09-2016, 02:40 AM   #26
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
As i mentioned in this Thread i am going to fit disc brakes including the hand brake at the rear.
So some months ago i bought new discs and pads for front and rear. New bearing were necessary also.
The rear setup consists of:
  • Rover Metro XP radius arms
  • hub from the donor car (unscrewed from the radius arms)and milled down to fit in the radius arm
  • Rover / Honda hoses (later i will go for steel covered hoses)
  • hand brake cables
  • calibers from a 1997 CRX delsol si
  • new 4.75mm cunifer hoses
  • pieces from the donor car for fiting the cables / hoses
  • hand made adapters for the rear calibers (will be milled from 7075 Aluminium
I started with this:
and went to this:
rear caliber hold in place:
holes for the cables and the water pipes (reason: the radiotor will sit in the rear frame [more will follow]) were drilled. To prevent rubbing some body plugs will follow
right rear caliber clamped in place and made some fixing points for the brake hoses:
this is the way where the cable will go go its way. I think i will change the cables into a longer one from a car with disc brakes
Holder for the hoses already welded on:
The way how the hoses will go through the rear frame without rubbing and touching the suspension:
Old 05-09-2016, 02:50 AM   #27
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
The adapter (draft) holds the caliber in place and everything fits together very neat
disc and caliber are now a very charming couple :P
In the inside of the mini i took the old mini brake lever (i forgot to save the honda's) so i manged it to this:
Old 06-09-2016, 07:04 AM   #28
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
because i like it to build from scratch, i tormented CATIA a bit:
rear brake adapter:
front brake adapter + technical drawing:
Old 12-09-2016, 05:26 PM   #29
Austinvti
Austinvti's Avatar
CC: 1590
ECU: P28 Standard
Default rear axle finished. Start of cooling system.
As i told, i like to finish the rear and go for discs of the honda, i did so and finished it finally:
Let pictures speak:
Sideview of how the hand brake cables will sit:
Due to the last moving from one garage to the new one, i lost so much parts what i need now . And because some parts are hard to find or the price is not worth to pay for, i built a holder and a levers from scratch to fix the cables.
Ingredients for this were only a old pair of drum brake holders and a bit of 2mm steel.
So i came with this:
resetting springs are still missing on both calipers, yet. But that counts to the solved problems
"Cooler radiator in the rear frame"
instead of using the honda rad or how i planed, to build in a cooler from the VW Polo G60, i bought a VW Golf 3 1.9 TDI Rad (very cheap and big enough).
I'd like to mount it between the rear spring housing like this:
Before i set up the final mounting points, i have to find a solution for this problem :P
Contact-alert
How to realize the air flow? First i thought to go for this:
To not build a undergroud spoiler and go for a short flight like Mercedes in 1999 with their CLR GT1, i will create a porsche like cooler cover with small vents and another guide which will let the air flow out faster.
The goal is to create a slight vakuum (downforce) that there is no lift effect because the Mini weighs not much at the rear. :P
Old 12-09-2016, 09:52 PM   #30
leon
leon's Avatar
nice work like the rear disc setup. Dont see a reason why the rad wouldn't cool, with a scoop and the amount of flow under the car it will be more efficient than a front mounted
I live like my blood type is B positive
