Old 14-11-2014, 08:33 AM   #16
keitht
Originally Posted by k20/k24 allmotor View Post
Wow. Looks like some body know how to rebuild a motor .. Really good bananas mate
Thanks Mate, I can't wait to get it running.
Old 14-11-2014, 07:15 PM   #17
keitht
The main bearing clearances worked out at:
1. 0.0255
2. 0.0355
3. 0.041
4. 0.028
5. 0.03
I still have to plastigage but they look ok.
The big ends will have to wait until I get a new Micrometer.
Old 14-11-2014, 07:29 PM   #18
keitht
I got the block sprayed as well, the picture makes it look very bright but it is a nice shade and very close to new cast aluminum. Time to get it back into the workshop and on the engine stand, I should get a bit more done over the weekend.
Old 14-11-2014, 08:00 PM   #19
Have you got a set of test bars you can use to take up the missing gap so you can use the big mic. Not the best but fully possible .
Old 14-11-2014, 08:13 PM   #20
keitht
I do and I would normally do this for simple measurements but it would be a right pain in the ass to set the bore gauge.
Old 14-11-2014, 08:19 PM   #21
Ok I didn't want you twiddling your thums or looseing sleep,lol
And you are dam rite to cheack the mesh enlist work before assembally top work,
Old 14-11-2014, 08:28 PM   #22
jimbob34
jimbob34's Avatar
Looks proper job keitht
Would be interesting to see what your measurements are for the big ends
Have been measuring mine today for double check
And still came out with being too tight.
jimbob34 is offline   Reply With Quote
Old 14-11-2014, 08:58 PM   #23
keitht
Ha ha not much chance of that I have enough work for 10 men!! Lol
Thanks Mate, What did your measurments come out at?
Old 15-11-2014, 05:19 PM   #24
keitht
I got a bit more done today. I picked up a new micrometer as well.
I decided to keep the oil squirters as I frequent the Nurburgring so this engine will experience extended periods of high RPM usage.
This is the assembly lube I use, it is very sticky and messy but works well.
Old 15-11-2014, 11:33 PM   #25
jimbob34
jimbob34's Avatar
You got the same micrometer as I got,also had to get a dial bore gauge
Had another go at measuring today with new metric tools
Big end crank journals
44.99
Rod ID
1/ 48.03
2/ 48.03
3/ 48.02
4/ 48.02
My new HX ACL bearings measure
1.47 x2 2.94
BC 1and 2 0.050
3and 4 0.045
Old 16-11-2014, 12:15 PM   #26
keitht
Thumbs up
44.99
Rod ID
1/ 48.03
2/ 48.03
3/ 48.02
4/ 48.02
1.47 x2 2.94
BC 1and 2 0.050
3and 4 0.045
I measured mine up this morning.
Crank journals are 44.99
Rod ID
1. 48.03
2. 48.02
3. 48.00
4. 48.02
Bearings are 1.47
Clearance
1. 0.05
2. 0.045
3. 0.035
4. 0.045
Did you platigage to check measurements?
Old 16-11-2014, 01:19 PM   #27
jimbob34
jimbob34's Avatar
Yes plastigauged after and was corrected.
A lot happier with these tolerances using the thinner HX bearings
Are you also using the ACL race HX?
Old 16-11-2014, 01:42 PM   #28
keitht
Good stuff, I'm not ready to fit them yet so can't platigage.
Did you have tighter tolerances with different bearings?
No I'm using off the shelf standard king bearings, I have photos of the part numbers on this thread somewhere.
Old 16-11-2014, 01:45 PM   #29
keitht
I got some more parts delivered over the weekend. B series gear linkage as my old one got binned by accident and an ITR flywheel which is in very good condition.
Old 16-11-2014, 04:42 PM   #30
jimbob34
jimbob34's Avatar
I first had ACL race bearings std
Then found out they do a thinner bearing that put me to my measurements within the top end of the tolerance
As the standard size was just bellow
