Old 21-03-2013, 07:36 PM   #16
miniphil30
ECU: Erm none yet
Could be good 3 heads are better then 1, I live in Sheffield so not from Chesterfield at all! What frame you going for...err Mat is it?
miniphil30 is offline   Reply With Quote
Old 21-03-2013, 08:22 PM   #17
fatmat25
fatmat25's Avatar
ECU: standard for the mo
[QUOTE=miniphil30;308346]Could be good 3 heads are better then 1, I live in Sheffield so not from Chesterfield at all! What frame you going for...err Mat is it?[/QUOTE
i've made the custom made the frame pal but not had the engine in yet so may need to be modified yet but we'll see
fatmat25 is offline   Reply With Quote
Old 22-03-2013, 12:01 AM   #18
Bennjamini
Finished off the arch tonight,
Put a few more tacks on the inner arch and the outer join with the quarter panel, and used the tin snips to trim the excess down to about 10mm, to create a stanard-looking arch lip:
Also, stitch welded the other side of the sheet panel, to the inside of the arch inside the car/boot
Slapped a load of rust primer on and bobs yer nob job done
Wasn't that happy with this the arch isn't as round as I'd hoped to get it, should've spent more time rounding it off with the snips.
Also, can someone tell me what this bracket fixed to the arch on the inside of the boot is -
Its been that long since I took everything apart, I can't even remember! I know it's not for the fuel tank, cos the filler opening's on the other side!??
Bennjamini is offline   Reply With Quote
Old 22-03-2013, 12:02 AM   #19
Bennjamini
We should all go for a pint sometime
Old 22-03-2013, 12:14 AM   #20
water bottle,
Old 22-03-2013, 09:28 AM   #21
Bennjamini
Nice one cheers!
Old 22-03-2013, 12:33 PM   #22
fatmat25
fatmat25's Avatar
sounds good to me pal!!!!
Old 23-03-2013, 09:30 AM   #23
Bennjamini
Guys!! Ive LOST the aerodeck!? I swear it was here last night??
Old 23-03-2013, 11:41 AM   #24
miniphil30
ECU: Erm none yet
I'm having the same problem, can't get into the garage as the door has vanished....
I'm up for a pint!
Old 23-03-2013, 01:15 PM   #25
fatmat25
fatmat25's Avatar
I'm up for a pint!
sadly gentlemen i'm in work trying to sell cars hahahahahaha lol
Old 23-03-2013, 02:05 PM   #26
Bennjamini
I'm up for a pint!
Sound let's do it
Old 23-03-2013, 02:06 PM   #27
Bennjamini
You got any 4x4's? or tracked vehicles even me dads landy can't get anywhere in this lot!
Old 23-03-2013, 02:44 PM   #28
fatmat25
fatmat25's Avatar
got 4x4's pal supprised the landy can't get anywhere!!!!
Old 23-03-2013, 08:33 PM   #29
Bennjamini
It's grounded look -
Road tyres don't help
2 ft snow helps even less lol
Old 23-03-2013, 10:13 PM   #30
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Woah, whereabouts on the globe are you located?
