Old 09-01-2013, 10:00 PM   #31
Freebies
Freebies's Avatar
CC: D15B
ECU: MTD Frame, not MTB
mini hubs, with mini cv's
Freebies is offline   Reply With Quote
Old 09-01-2013, 10:00 PM   #32
Freebies
Freebies's Avatar
CC: D15B
it is designed to fit with the mini ball joints.
Old 15-02-2013, 03:21 AM   #33
30 mm
30 mm's Avatar
ECU: square case
Got me some break assembly!!!
Old 15-02-2013, 03:53 AM   #34
Freebies
Freebies's Avatar
CC: D15B
So what size have you got ?
Old 17-02-2013, 03:01 PM   #35
30 mm
30 mm's Avatar
ECU: square case
they are 8.4
Old 01-03-2013, 11:46 PM   #36
30 mm
30 mm's Avatar
ECU: square case
The Mini takes a back seat ride down the road to a friends. Obviously its cold and he has a heated garage and a 220v mig welder. Gonna try and finish all the welding during our march break period.
More to follow
Old 06-03-2013, 01:58 AM   #37
MiniMike
CC: 1500
ECU: Honda standard p08
What's all that white stuff? We're mowing the lawns out here! Nice to see the car coming along..It will be strange to have another Mini30 VTEC around.. probably the only two in Canada!
89 Mini 30...finished the car ... again!
MiniMike is offline   Reply With Quote
Old 06-03-2013, 03:12 AM   #38
30 mm
30 mm's Avatar
ECU: square case
Mike,
I lived two years out in Vic while my parents were posted there with the fleet. You cant tell me your mowing lawns just yet!!!
But seriously when this is done Id like to drive her out all the way the BC with my son. Give it two years.
Serious question. Im about the separate the door step from the inner sill. Inner sill has to go. Whats the best way to do this without messing up the door step.
THnaks
Old 06-03-2013, 03:21 AM   #39
MiniMike
CC: 1500
There were a lot of lawn mowers going this weekend past! I would drill out the spot welds from the door step side, then cut away the inner sill leaving the strip attached to the door step, and then grind away whats left from the sill side.. that should leave the door step in one piece, and ready to plug weld onto the new inner sill..hope that makes sense. BTW I have done several trips with my son across the Us in the VTEC Minis I have build, and it was a great thing to do.. I kept up a blog so the club and family could come along for the ride. We did Victoria to Rockford Illinois for an East Meets West meet...plus a few shorter ones, ie San Francisco, LA, and Portland trips as well.. good luck with the build!
Old 06-03-2013, 06:33 AM   #40
TurboMini
TurboMini's Avatar
I've been mowing my lawn every week since the end of January. I mow it at least once a month all year. Fact.
email - turbomini@gmail.com
67 Traveller - JDM B16A Standard length.
www.victoria-chiropractors.ca
TurboMini is offline   Reply With Quote
Old 09-03-2013, 06:50 PM   #41
30 mm
30 mm's Avatar
ECU: square case
Guys I thought I understood how this car came together but I scared myself yesterday. At the door post I have to understand how it all comes together.
Am I correct when I think the front has the flitch panel, it goes to the door post. The bottom of the door post is attatched to the sill and floor board. Now on the inside of the car is it also attached to the bulk head??? If so does the bulk head meet up with the flitch panel as it goes towards the center of the mini? Here is the pic.
Old 10-03-2013, 08:18 PM   #42
30 mm
30 mm's Avatar
ECU: square case
Work continues today.
Bondo was discovered which was a real downer. The previous owner told me there was none.
Results
Old 10-03-2013, 08:22 PM   #43
30 mm
30 mm's Avatar
ECU: square case
continued
Old 10-03-2013, 09:50 PM   #44
Freebies
Freebies's Avatar
CC: D15B
That is serious work... Be sure to brace the car enough so it doesn't get out of shape. Also, before removing too much meat, start refitting new panels. Just my advice!
Old 11-03-2013, 02:25 AM   #45
30 mm
30 mm's Avatar
ECU: square case
Thanks Freebies,
I have some metal being shipped this week, some fabrication is being done and I hope to get most of this done within 7 days cause then Im on the road!
30
