Old 02-07-2011, 04:09 AM   #1
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Default B18C1 MiniTec Build AKA Frogger
This might be a little premature but it's where I'm at so far.
Picked up my first mini cooper after contemplating building a superMini for a while. Found it in a surrounding state for a good deal. Owner had previously finished 95% of the body work. New panels all the way around. (fenders, hood, floor pans, front and rear vailences, grille assembly) Rebuilt engine/tranny w/ new hubs. Cosmic wheels, 8.4" Cooper S Brakes. LHD.
The Engine was done to a 1300 and will be going up for sale shortly. I belive it was a Metro 1275 motor.
We got him home and as for all the cars around here, it must be given a name. I have decided to go Bugadi British Racing Green and Frogger just stuck.
2000$ USD w/ trip expenses.
Leaving Colorodo
Home!
Old 02-07-2011, 04:14 AM   #2
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
One more peice aquired. Out at the Wrecking auction I happened to notice a GSR Integra waiting for a home. I decided he should join the project.
All told w/ taxes & fee's: 1145$
B18C1 !! woohoo so excited!
Selling the parts off the Integra should put me around 200$ spent for the Engine/Tranny/ECU/Wiring harness
Old 02-07-2011, 08:54 AM   #3
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
good deal on the mini. wonder what happened to the gsr. looks like someone hit something pretty hard, is the block ok. the header is all smashed up against it. otherwise looks like a good deal. keep us posted on the progress.
Old 02-07-2011, 02:46 PM   #4
Mini fab
Mini fab's Avatar
ECU: PO8/ Chrome
The alloy are rare Cosmics 13" keep it up!
5 speed is not an option!
Mini fab is offline   Reply With Quote
Old 02-07-2011, 04:47 PM   #5
64van
64van's Avatar
ECU: P30
Great start Keoman. That sounds like a really good price for your GSR donor. I paid more for a JDM Civic SiR.
64van is offline   Reply With Quote
Old 02-07-2011, 09:28 PM   #6
Kam
Kam's Avatar
Nice to see another honda in the making Oh and yeah, that GSR looks like a willing participant
B18C1? Interesting, never heard of this one before, over here we only get to hear about the C4/C6's
Good luck and looking forward to the build
Old 02-07-2011, 09:39 PM   #7
billing5
billing5's Avatar
CC: 1500
ECU: cbr carbs
Send a message via Yahoo to billing5
hi, b18c1 is identical to the c4 we have, just the state side engine code. that header does look bashed into the block could be the pic making it look worse though, good luck anyways
billing5 is offline   Reply With Quote
Old 02-07-2011, 11:51 PM   #8
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Thanks guys,
The parts on the teg got pretty smashed. VTEC KICKED IN YO! Radiator, Headers, Power steering pump, AC pump, clutch slave cylinder, shift linkage... the engine/tranny were crunched about 3 inches from where they sat originally. Luckily almost all the parts that got smashed/broken/bent are pieces that I dont need.
The Dirvers side engine mount looks to be in questionable condition. Not sure if its broken or not. If it is, might be time for a B20 block swap for some extra Ft/Lbs of roasting power! Theres no replacment for Cubic Displacment I always say.
Just got done today rebuilding the engine in my 1989 IrocZ. 193,xxx miles and just a little head gasket / intake manifold gasket antifreeze leak.. not bad Camaro.. not bad
Time to dive head first into the Mini! Im so excited.
Old 03-07-2011, 01:31 AM   #9
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Could you expound a little on that?
Old 03-07-2011, 08:25 AM   #10
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
there is a few minor differences. the cams are a little more aggressive on the c4,
C4=In: 239 dur/ 10.8mm lift - Ex: 235 dur/ 9.4mm lift
C1=In: 230 dur/ 10.6mm lift - Ex: 227 dur/ 9.4mm lift
not enough to change over to c4 cams from c1's, but better.
and well thats about it.. the p9k is is a lot softer than the p72 which is why the c1 puts out a tad bit more power but thats easily changed with hondata or u can just get an obd1 p72 and basically plug in a few more horse power.
Old 03-07-2011, 11:54 AM   #11
Mini fab
Mini fab's Avatar
ECU: PO8/ Chrome
What I mean those Cosmic alloys are very rare since the company Cosmic doesn't do those alloys anymore ( they shut down), It's a part/ accessories you try to keep, for they will appraise there price later on, and good for any Mini in the Park shows.
Old 03-07-2011, 06:24 PM   #12
billing5
billing5's Avatar
CC: 1500
ECU: cbr carbs
willp99, what do you think the power gains would be swapping to the p72, worth it or not also how would you go about the p9k immobliser
Old 03-07-2011, 10:04 PM   #13
Keoman
Keoman's Avatar
CC: B18C1
ECU: Chipped P06
Great. I will definatly hold on to them. You wouldn't happen to know if they have the 7mm offset the MiniTec kit requires do you?
Old 03-07-2011, 10:20 PM   #14
cooper_mark
cooper_mark's Avatar
have a nosey here
http://www.wheeldictionary.net/
might be of some help
my beast
Old 03-07-2011, 10:56 PM   #15
Mini fab
Mini fab's Avatar
ECU: PO8/ Chrome
That's one catch using Minitec frame you have to clear at least 1" thick spacer if you re using wide alloys, and for this Cosmic I'm not really sure if an inch spacer will do as they recommend it, when using there aftermarket brake calipers .
